Tires Wheel Spacers and weights for a new BX2370
   / Wheel Spacers and weights for a new BX2370
New BX2370 arrives tomorrow.
I have decided to go with R4s instead of turf tires. The actual area of planted grass I want to be careful with is small. The majority is yard / field so a couple of dings in that won't bother us. Snow is mild here - only a few inches. We may get a foot once in a while but not lately. Balancing this against a third of the property is pasture and a third woods and all the SCUT trails to get firewood I decided the R4s would be best.
I am sticking with the 54" MMM. My tight clearances are not just one sided but between things. Unfortunately it doesn't look like I can add wheel spacers with the mower deck on. So wheel spacers are out for now. We'll see if two setups are warranted: one with MMM and nothing else and the other with the FEL, spacers, and what not. I need to experience the difficulty of removing and installing the MMM, FEL, and rear implements.
Filling tires (the rears only) are out for now as well. My dealer is not a Rimguard dealer. Both nearest dealers for Rimguard, Carson City NV and Red Bluff CA are quite a drive. I won't install just water and if I think I need it I'll make that drive at some point.
And - I am getting a rear 4' box blade instead of the Kubota ballast box. The dealer has only sold two, made the same recommendation as the forum, and showed me a picture of how far back the ballast box hangs. I am just not saving much maneuvering space over the box blade.
All these choices probably do not match anyone's here 100% but then most of the posts helped with my decisions. I think I'll be happy with the near stock configuration until I learn my limitations. I have all day tomorrow to play (President's Day)!
   / Wheel Spacers and weights for a new BX2370 #22
Sounds great Sam! I think you might be able to get BX spacers on with the MMM but not sure of size and capatible MMM width. I don't own one but I love my spacers. Do some research on the spacer size... I thought I recalled you could get the narrower ones on with the MMM but check it out if you haven't already. Maybe you can measure your clearance after you get it.
2007 Amkus Rescue System (A56857)
2007 Amkus Rescue...
Deere 310L (A53317)
Deere 310L (A53317)
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
Club Car Carryall 2 Electric Utility Cart (A55851)
Club Car Carryall...
2003 International 9200I (A53317)
2003 International...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
