Wheel weight
   / Wheel weight #22
I MUCH prefer radial tires on my tractors and putting fluid in radial tires greatly defeats the traction advantages of radial tractor tires.
SR
   / Wheel weight #23
A 55 gal drum of concrete t just isn't heavy enough. I put fluid in my tires, 2 95lb wheel weights and a 1700lb block of concrete off the 3pt and I could still make the rear end light.
   / Wheel weight
For loader work ballast, how about a drum full of concrete with a 3 point hookup on it?
3 pt. weight ballast - $125
3 pt weight ballast is your best bang for the buck for FEL work. I used a rear scraper blade until I got my wheel weights made, but trying to turn around in between trees I was like a bull in a china closet. I really like not having anything sticking out to worry about when I'm in the woods.
   / Wheel weight
WOW! That's one heckuva bucket full!
   / Wheel weight #26
It sure is. A 78" HD jd bucket on a 563 nsl loader full of wet clay. My front tires have taken a beating in the shale that I had been moving. I'm def going wi th heavier ply radials when these won't hold air anymore. I think I'm going to have to make a heavier steel weight since I snapped the cat 1 bar that was in the weight this winter. I'm going to shoot for 2500lbs this time.
NEW Thiessen Track Closer Disk (A55218)
NEW Thiessen Track...
Year: 2015 Make: Ford Model: F-350 Vehicle Type: Pickup Truck Mileage: 66,687 Plate: Body Type: 2 (A53422)
Year: 2015 Make...
2010 Nissan Rogue SUV (A53424)
2010 Nissan Rogue...
UNUSED RAYTREE RMBD72 - 72" HYD DRUM MULCHER (A54757)
UNUSED RAYTREE...
Galvanized Livestock Wire Gates (4X Gates) (A55218)
Galvanized...
UNUSED WOLVERINE CB-11-750F HYD CONCRETE BREAKER (A54757)
UNUSED WOLVERINE...
