When I buy, what to look for.
   / When I buy, what to look for.
I'll know more tomorrow. The cutter and blade are Darrell Harp stuff. They sell bad boy stuff there so I'll be asking to swap them out if I decide to buy something. Still leaning 2510 unless the bigger ones knock my socks off.
   / When I buy, what to look for. #12
Since it's going to be my first purchase of this type. I'm wondering what the gotcha things are and what to make sure is included with my purchase.
I'll be purchasing tractor, loader, box blade, rotary cutter and trailer. Whether it be a package or whatever. What are those things that are typically not included that prevent you from working with your new purchase. What things can I include that will prevent me from being dead in the water?
Here's what I think I know. :laughing:
1. Some tractors don't come with a top link. I'd think it ought to be put on the trailer for you with rotary cutter on with top link.
2. Rotary cutters don't usually come with extra shear bolts or gear boxes filled with gear oil. No, no shear bolts. Really should have gear oil. Both my cutters have had.
3. I probably should get a full 50hr kit. Why? Typical usage is 60/yr. That's near a year away.
4. Couplers? The things you use to attach to the 3pt? Not sure on this one. Look at what is provided. Often they aren't the best. Can do better at TSC.
5. Chains and straps for the trailer. Never bought with trailer, but I'd think they should provide.
6. See if they'll let you lift and lower the rotary cutter (likely put on it) to make sure they have it in the right 3ph holes or pin position on the cutter. My 1st cutter didn't have the pins in the correct position, and I've read herein where this has been the case for others. The top link has to be not longer than the bottom lift arms.
7. Rear tires should come loaded, or they should provide a ballast box for the 3ph.
8. May not come with a tool box. Certainly won't come with a fire extinguisher.
What things should I buy extra of to keep me going? What am I missing?
The pooter says I have to have something here. I added comments within your quote.
Ralph
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
New/Unused Fuel Pump with 50ft of Hose (A51573)
New/Unused Fuel...
2015 DODGE RAM...
2006 Nissan Xterra 4x4 SUV (A51694)
2006 Nissan Xterra...
2023 JOHN DEERE 8R370 LOT NUMBER 220 (A53084)
2023 JOHN DEERE...
