Where can I find ready made bushings?
   / Where can I find ready made bushings? #1
dex3361
Elite Member
N. of Charleston WV
Kubota L4400-1 HST,FEL, 3x3 remotes, TNT. BX1500 54 mmm
I am getting ready to make a grapple for my FEL and the only issue in my way is what to use for bushings on the pivot points? I know I could use something like black pipe but I would think it would be to soft. I do not have a lathe so I want to stay with what I can make work by purchasing the right ID. Any help from the TBN brain trust would appreciated. Thanks.
   / Where can I find ready made bushings? #3
Have you looked at DOM tubing?
I have had good luck with this for bushing that I drill and tap a grease fitting. Local I have trouble with small amounts (less than 10ft) but I have ordered from Speedymetals a couple times. Below is the link to the round tube. The DOM tubing does not have any welds in the inside and you can get different thicknesses.
https://www.speedymetals.com/s-204-round-tube.aspx
   / Where can I find ready made bushings? #4
Timkin bearings makes some real nice bushings available with most common id and od's That is what Bobcat uses for their backhoe boom bushings.
Ken
I knew I could count on you guys, thanks. I appreciate all of the input.
Thanks Jim
1999 CAT 350E2 Haul Truck (A55272)
1999 CAT 350E2...
2013 JOHN DEERE 650K LGP CRAWLER DOZER (A52709)
2013 JOHN DEERE...
KMC 6R30" RIPPER / HIPPER (A52708)
KMC 6R30" RIPPER /...
2007 IC Corporation PB105 School Bus (A54814)
2007 IC...
2019 VOLVO ECR145EL Excavator (A59213)
2019 VOLVO...
2018 Ford Transit 150 Cargo Van (A56858)
2018 Ford Transit...
