Where do you guys get your shear bolts??
   / Where do you guys get your shear bolts?? #11
The TSC's here have grade 2, 5 and 8 in good supply. I use grade 2's. Would be concerned about using 5s.
   / Where do you guys get your shear bolts?? #12
Mine came with the grade 2 bolts or whatever they are called and I broke them real fast. My dealer gave me a handful and said that's what they are supposed to do. After I broke all of them, I went back for more and he gave me grade 5 bolts. I asked why the change and he said that everyone was breaking them so fast that they upgraded to grade 5 so that you could actualy get some mowing done. I've been using grade 5 bolts since then and only break them on rare occasions. I still have a few left from the handfull he gave me something like four years ago.
Eddie
studor said:
I am begining to believe that every bolt made in China is a grade 2:eek:
LOL! studor.
I just thought of the faster places this am as well. I'll make a stop in to Acklands Grainger this afternoon I think.
   / Where do you guys get your shear bolts?? #14
Same here, both my local TSC's have grade 2,5 and 8 also.
   / Where do you guys get your shear bolts?? #15
Maybe there needs to be a new grade system. Grade-2-U which is the standard US made grade 2 bolt and Grade-5-C which is a standard China made grade 5 bolt.......which is equivalent to the Grade-2-U.
And on top of that Anheiser-Busch is owned by Belgians. What is the world coming to?
Eddie, is yours a heavy duty bush hog or a standard duty? It wouldn't shock me if my dealer put it a grade 5 originally in my bush hog. I
haven't broken the thing till the third season and I've had several encounteres where I thought I should have. Except back think I thought the 'slip clutch' which my bush hog was supposed to have would have been slipping :) I'm not on talking terms with the dealer so I'll probably just put in grade 2s and buy several replacements and see how it goes.
   / Where do you guys get your shear bolts?? #17
Do you have the bolt that broke? I'd check the diameter too. My bush hog owners manual called for the same size as yours, 1/2" x 3", grade 2. When I broke a shear bolt I discovered what was installed (when I bought it) was actually only 3/8" diameter so there was some excess play in the hole. I don't know if that had anything to do with break but I don't think it is an ideal situation. Then I also discovered the hole will not accept a 1/2" daimeter bolt so the manual is wrong. I ended up using 7/16 diameter which fits in hole snugly without escess play and have not had one break since. The dealer I bought the Bush Hog from was kinda clueless about this. I found a local hardware store guy that to purchase from.
   / Where do you guys get your shear bolts?? #18
my grade 2 bolts come from the "common" bin at any big hardware store.
If there is a question, i check the head for grade stampings, if none are present, its fine for shear bolt duty for me.
   / Where do you guys get your shear bolts?? #19
Eddie, I was using 3-1/2" grade 2 bolts and going through several everytime I ran my cutter. Then, I started looking at them and noticed that the threads were taking part of the shear load. I went to 4" bolts to get the threads out of the shear force "zone" and my bolts last much longer.
   / Where do you guys get your shear bolts?? #20
Hello
Go to Canadian Tire
That is all that they sell any more
Regards
DGS
2024 New Holland T8.410 MFWD Tractor (A55314)
2024 New Holland...
2021 Delta Manufacturing 30ft 10-Ton T/A Gooseneck Flatbed Equipment Trailer (A55851)
2021 Delta...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
2014 K-Z RV STONERIDGE 38FT RV TRAILER (A58214)
2014 K-Z RV...
48ft all aluminum feather light wedge trailer (A56435)
48ft all aluminum...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
