Where do you guys get your shear bolts??
   / Where do you guys get your shear bolts??
DGS - thanks!
I wasted my time and went to Acklands Grainger. For starters they only had grade 5 and up. Plus they wouldn't sell to me because they only sell to businesses. Never heard of that before. Pretty daft if you ask me - turn away a customer who drove to your store!.
Called the Kubota dealer parts dept who I have been using for parts. He said basically they use grade 5 for everything. His claim - a grade 5 will shear just as quick as the grade 2 will and you wont' harm anything. He said, just don't use grade 8.
He's the second dealer now to say that they just use grade 5. I guess you guys in the USA are just spoiled with all the choice you have down there - grade 2, grade 5 and grade 8.
I'll drop by the local Lowes and Cdn tire today. See what they have.
   / Where do you guys get your shear bolts?? #22
I don't know enough about this to contradict your dealer, but why on earth would a grade 5 shear with the same load as a grade 2? That doesn't make any sense to me. If that's true, then shouldn't a grade 8 shear at the same load as a grade 5? Its the same sort of statement.
   / Where do you guys get your shear bolts?? #23
In a pinch I've used nails for shear pins. But as a rule, using anything but the factory original is just not smart. If a TSC bolt made in China is $ 0.50 and a factory shear bolt is $ 1.00 it's the cheapest insurance against damage you'll find.
It's a no brainer. Get the original.
Brent - I don't think that there is such a thing as a 'factory shear bolt'. My guess is that not enough people have a need for anything much less than a grade 5 around here. Although off to Canadian Tire I go as DGS suggests. If they have grade 2s then I'm going to buy a dozen!
George, I'm sure what he meant was that grade 5 would shear just as well as grade 2 if you hit something that was actually going to do damage.
Now I don't really know if thats true or not. I'd rather stick to the manual but it sure does seem like many folks up here run grade 5s and nothing else - including both dealers that I deal with - one Kubota/New Holland dealer and one Mahindra dealer.
Maybe they are both using those chinese grade 5 bolts which are equal to US grade 2 :D
Hey Brent - just realised that you are not that far away from me. I'm up in Queensville - probably about 40 min away from Caledon.
Great to see some more local guys here. Welcome!
   / Where do you guys get your shear bolts?? #26
Look in your local yellow pages for Fastenal -- pretty sure they sell to the public -- Acklands has always been a PITA to deal with -- and there prices are not great anyway:mad:
As some one else mentioned, make sure the unthreaded part is long enough to act as the bearing surface and yes, grade 5 will snap quite nicely IMHO
   / Where do you guys get your shear bolts?? #27
I agree. The dealer is not a metallurgist. A grade 2 has a tensile strength of 74,000 psi. A grade 5 has a tensile strength of 120,000 psi. All other things being equal, the grade 2 bolt will break before a grade 5 would (and also before something more expensive breaks). Since this is what the manufacturer has tested and recommended, it makes sense to me to use what the manufacturer specifications say to use.
I was going to drop by the Fastenal store tomorrow but dropped by the Canadian tire on my way back from work. Mostly grade 5 stuff but lo and behold I did manage to find some grade 2 bolts that are in the size that my manual calls for.
There were 4 on the shelf. I am now the proud owner of the only four grade 2 1/2 NC x 3" bolts in this neck of the woods!.
I'll check on the unthreaded length when I put it in the mower tomorrow. Gotta bush hog a pasture after work.
Since I was able to find grade 2, I'm happy to stick with it. If I had much more hassle finding any after dropping by Fastenal and Lowes, I would have gone with grade 5. I'm willing to bet my bush hog had a grade 5 in there to begin with.
I'm probably going to stick with the grade 5's for my snowblower the Mahindra dealer I purchased from has been selling me. Broke 3 last year and he swears that it is the only thing he is using and he sells a LOT of these blowers. Plus the manual has the wrong size of bolts heck... so I just drop by his place and he sets me up with the sizes that are right for my blower.
Thanks for the help folks!
   / Where do you guys get your shear bolts?? #29
for sure you can get away with a lot on shear bolts. On my Kubota the shear bolts are actually turned to reduce the diameter. Looks like a snap ring groove.
I've busted more than a few while I learned where all the rocks are and it was not a fluke. Every package was machined the same way.
To save 50 cents against gear or other damage. Go ahead. Roll the dice.
You won't appear on the national poker finals playing those risk reward odds.
Brent - is this a Kubota mower that you are referring to you replacing shear bolts on?
I've got a Woods rotary cutter and I've not heard of Woods making 'factory' shear bolts. I would probably buy them if I found a convenient source too.
Kubota has all sorts of OEM stuff for everything they sell. Heck the Kubota dealer I use for parts even sells OEM 15W40 oil!
Anyway, since I've got grade 2 as per manual, I am happy as a clam :)
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
Set of 4 10-16.5 Bobcat Wheels and Tires (A56857)
Set of 4 10-16.5...
Stanley Hydraulic power pack (A56435)
Stanley Hydraulic...
2021 Freightliner Cascadia 116 T/A Day Cab Truck Tractor (A55973)
2021 Freightliner...
Gas Pump Artwork (A55758)
Gas Pump Artwork...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
