Where is my grease going???
   / Where is my grease going??? #21
Don Sullivan has your answer. There are large cups on the RCK deck underneath the spindles, above the blades. They are approx 5"-6" dia and about 3" high. They catch the grease overflow, and would take (I guess) close to a full tube each to fill.
So I'm looking for overflow on the bottom cups then right?
   / Where is my grease going??? #23
I've been using Slick 50 grease, it's a pretty green color.
"I'll either find a way or I'll make one"
John
John
   / Where is my grease going??? #24
The cups are almost the size of a sour cream container (a little shorter) You are going to waste an awful lot of grease if you're determined to fill them. If you ever unbolt the blades for sharpening or replacement the cups will pull off. or more likely fall off if they're full of grease.
I agree with you. I also remember a while back reading about a person who lost the bottom bearing and ruined his spindle due to too little grease in the deck. I'm faced with hoping it has enough of fill it until I see grease coming out somewhere.
Because I paid more for the deck then some whole tractors cost, add me to the grease waisting society TBN membership. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Where is my grease going??? #26
After reading all these posts of pumping in different pretty colors of greases into a joint, it sent off alarm bells. Not all greases are alike...you might be mixing two types of greases which could break down and not do any real good. The greases have to be compatible! Here's a good link to help you determine if the brown one will go with the blue one. There is science to grease...or is it Greece!
http://www.mindconnection.com/library/handyman/greasecompat.htm
   / Where is my grease going??? #27
</font><font color="blue" class="small">( ................The greases have to be compatible! ............!
http://www.mindconnection.com/library/handyman/greasecompat.htm )</font>
All this is great information, however until we find out the brand and specification of grease is being used at the assembly plant that manufacturers the spindles, all this is academic...
   / Where is my grease going??? #28
junkman you mention about cross contamination when mixing greases? is this a big issue. i have mixed greases in the past and dont seem to have a problem /forums/images/graemlins/confused.gif
   / Where is my grease going??? #29
It can be if the type of grease isn't compatible with the grease that you are putting in. If you want to learn more, here is a web page that covers the subject. If you would like to stay on top of the subject, you can subscribe to the free WEB magazine. I get it and it always has interesting articles, even if they are not tractor specific. Read a lot, learn a little.... /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
   / Where is my grease going??? #30
i am switching to kendall grease. i am just going to add new grease and this should flush out the old grease on the mmm and the fel.
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
2757 (A55787)
2757 (A55787)
John Deere Gator XUV560S4 4x4 Utility Cart (A50324)
John Deere Gator...
BUSH HOG 2615 - 15' BATWING MOWER (A51243)
BUSH HOG 2615 -...
2011 EAGER BEAVER 35G SL DETACH TRAILER (A52706)
2011 EAGER BEAVER...
Michelin CARGOXBIB High Floatation Tires (SET OF 4) (A55301)
Michelin CARGOXBIB...
