Where is the hydralic fluid level check?
   / Where is the hydralic fluid level check? #11
Anybody known what fluid to use?
Frank
   / Where is the hydralic fluid level check? #12
I forgot to ask, anybody have a cross reference for the 4530 hydralic fluid filter.
Frank
   / Where is the hydralic fluid level check? #13
JOEAA- I USED THE MOBILE 424 HYDRALIC FLUID IN MINE. DON'T KNOW A CROSS REFERENCE FOR THE FILTER BUT MAKE SURE TO CLEAN OUT YOUR HYDRALIC STRAINER. I CHANGED MINE AT 50 HOURS AND THE FILTER AND STRAINER WERE BOTH DIRTY.
   / Where is the hydralic fluid level check? #14
I have a 2016, 4540. The hydrolic system on mine has 2 drains. One is located just in front of the strainer, the other one is just below the power take off shaft.
When you take out the front plug, the system does not completely drain. I think it leaves about 3 gallons of fluid in the sump. This works well if you are servicing the strainer.
The dip stick is between the seat and gear shift lever and just to the right. It is under a big, about an inch, nut. This is also the fill point.
Lone Star dump trailer (A55973)
Lone Star dump...
2025 40ft. High Cube Shipping Container w/ 1 End Door & 4 Side Doors (Est. Retail Value ($12,000)... (A59225)
2025 40ft. High...
2005 John Deere 200C LC Excavator (A59213)
2005 John Deere...
CAT930K (A58216)
CAT930K (A58216)
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2000 ITASCA SUNCRUISER 37G CLASS A RV (A58214)
2000 ITASCA...
