Big Barn
Super Member
- Joined
- Aug 20, 2013
- Messages
- 6,874
- Location
- Victoria, B C
- Tractor
- More than 40 over the years. Ten at any one time. Mostly Ford and New Holland
Terry, I like that a LOT. Great place to store chains, blocks, etc. Low profile which I like. How many gallon is it? I've never saw one like it.
Wish you were my neighbor. We'd be in negotiations right now.![]()
Very nice. Only thing I'd want different would be fill cap next to the pump so everything could be done from one side. With it like yours I'd be parked on the wrong side of the refuel pump every time.....
Trailor vote also.
Is it a tilt bed trailor ?
Just curious if it could be mounted aboard the 2 inch square tubing that the winch is mounted to. Other words in between the winch and spare tire. Going to have to rig up some mounting brackets and whatnot anyway. Or better yet mount the tire in between the fuel tank position in the mockup and the winch. Basically raise and reverse to the rear the tire mounting bracket.
Can tire be mounted on side of trailor ? Should not hang out past fenders. Just personally would hate to mount and remove a spare tire from under the trailor. Bound to be a bad spot on the side of the road, etc.
I do that with nearly everything. In this case, the 5th wheel hitch frame would play the part of the pallet. The puck mount means you throw 4 levers to mount or dismount it. As they are rated for 20k+ lbs, 350lbs of aluminum tank & 36 gallons of diesel should be plenty secure. Unlike a pallet you'd have to otherwise chain down or something.I put my 100 gal transfer tank on a pallet. So I can put it in the back of the pickup to fill, or take it to where the tractor is, or put it on the trailer, store it in a shed, whatever is needed.
