Which 15" Tire Trailer is Better??
/ Which 15" Tire Trailer is Better?? #1
dieselscout80
South Carolina
New Holland TC45DA
Yokohama - 7.00R15
Max load 2040 lbs; Max 65 psi; tread depth 13/32"; dia. 29.4"; rpm 706
or
On The Wings of Goodyear | RV Tires - Tire Selection - Marathon® - ST225/75R15 D
Max load 2540 lbs; Max 65 psi; tread depth 10/32"; Dia. 28.3"; rpm 736
or
Sorry - File Not Found - 235/75R15
Max load 2337 lbs; Max 65 psi; tread depth 14/32"; Dia. 28.9"; rpm 720
The Goodyear has a highest weight rating, but the Yokohama looks to be a good tire.
One other thing has anyone ran Westlake trailer tires?
/ Which 15" Tire Trailer is Better?? #2
You are not comparing apples to apples. Different sizes yield different load ratings.
My personal experience is the Marathons are junk. I had a set on my car hauler trailer bought new in 2007 and lost 3 in 2 years hauling no more than 5,000# most of the time on a 7,000# trailer. I replaced them with Greenballs last spring and not a single issue and now have loaded the tires on my tractor so its heavier.
Chris
/ Which 15" Tire Trailer is Better?? #3
I put a set of Marathons (ST215 75 R14) on my boat trailer last year. They used to made in China, but because of the problems they were having GoodYear moved production back to the States....North Carolina I believe. I made sure mine said Made in USA before I would let them be mounted. I've never heard of Grenballs in my neck of the woods. Anyway, so far...so good:)
/ Which 15" Tire Trailer is Better?? #4
I had 4 Marathons on my Holiday Rambler Aluma-Lite 34' Travel trailer and when we were in South Dakota one blew off the rim. never seen a tire come apart like that before, piece of the tire bounced off the top rim of the windshield of father-in- laws truck. No damage to his truck though.I now run Carlisle or Maxxis E range only.
DevilDog
/ Which 15" Tire Trailer is Better?? #5
If you have room, move up to 16" wheels and tires. You get a lot more tire choices.
/ Which 15" Tire Trailer is Better?? #6
DevilDog
Around here Carlisle is a dirty word but the Maxxis is most folks second choice after the Greenballs. Last set of Carlisle I had on the boat trailer in my avitar had 5 total failures out of 7 tires in less than 2,500 miles. I replaced with Greenballs of the same size and load range and not a single issue in 4 years. I would not hesitate to put either Maxxis or Greenballs on any trailer I sell, service, or own but will not touch a trailer with Carlisle or Marathons again.
Chris
/ Which 15" Tire Trailer is Better?? #7
I agree. D rated tires are OK but they can be tricky for a flat bed trailer that may haul a tractor and here is the reason why.
Let us say you have four 2000 pound rated tires. Loading the load so you get equal weight on each tire typically is not even possible and that is why tire experts use the 80% rule to help prevent blow outs due to overloading a tire.
In my view it takes at least a "E" rated tire (+/- 3000 pound rating) on an equipment hauling trailer. The next time you see a bush hog with 4' hanging off the back of the trailer look and see if the load is equally split between the four tires. :D
/ Which 15" Tire Trailer is Better?? #8
I agree with wvpolekat. I've owned many types of trailers over the last 55 + years and when I bought tires they had to be made in the U.S.A. In 2006 my PJ Flatbed Cargo Trailer came with tires I never hear of. They were Freestar Radial Tubeless ST 235/80R16 ET-108MS Tires (Made in China). Over 45,000 miles later I still have a lot of rubber left and they have held up better than most tires that I've owned. Every 2 to 6 months or so I make my run from the SF Bay Area where I still own a house to my place up at 8,000' in the Rockies (2,600 miles round trip) and that includes heavy loads of up to 12,000 lbs GVW with outside air temps of 122 degrees F going thru Needles, CA enroute on Hwy 40. The killer of tires is heat, under-inflation, and high speeds. I try to keep my diesel engine at just under 2K RPM in 6th gear with cruise control holding about 65MPH with occasional 70 to 80 MPH when passing and the tires run cool. A good place to read comments regarding tires is:
RV
Good luck,
Jim
I'd love to switch to 16" tires that would make the choice easy, but I'm having issues finding 16 wheels the fit my GM 5 on 5" hubs.
/ Which 15" Tire Trailer is Better?? #10
If you are running 5 lug rims you are more than likely running 3,500# rims so D rated tires will be fine. You will not see 5,200# or 6,000# rims until you get into 6 lug rims.
The heat and under inflation tip is a great one. I tow weekly. I did 400 miles last week and will do a solid 350 tomorrow. I always check the pressure before I set out.
Chris
/ Which 15" Tire Trailer is Better?? #11
Personally, if I have a choice, 16" for any trailer with a GVW over 5K although you can get LT or XL tires in the 15" rim size that for a set of 4 will get you WAY over 8K with a good safety margin.
In my experience, heat is the BIGGEST factor in tire failures, yes even with the Exploders ;)
How do you get heat in a tire? Pavement temperature and sidewall flex. In TX where blacktop temps can easily reach 140*F you are starting out at a big disadvantage even empty. Add a little under inflation relative to the load, and a little speeding and you have a receipe for disaster. Others have also mentioned this in different ways.
The inflation pressure for ANY tire depends on THREE FACTORS:
1) Load
2) Speed
3) The TIRE Manufacturer's recomended inflation
Increasing #1 and #2 will also increase the needed air pressure in the tire, increasing both #1 and #2 at the same time will REALLY require more air in the tire(s).
ALL tire manufacturers have "Tire load and Inflation Tables" for each tire model they make. Obtaining this information is quite difficult unless you have a much better than average tire dealer/distributor.
/ Which 15" Tire Trailer is Better?? #12
And old age. Nothing like a tire past it's "best used by" date. Those will shred in the heat. Heavy sigh.
/ Which 15" Tire Trailer is Better?? #13
I've never had a problem with Made In USA tires...
The tires on some of my antique cars are more than 50 years old and never a problem... some sizes are not even made anymore.
I have to believe the quality control just isn't on par today...
Heck, I've got a 1958 FibreFlite boat that I show occasionally, the boat trailer still has the 1958 Goodyear Wide White Wall Tires it came with in 1958... (The Boat and Trailer always been garaged)
/ Which 15" Tire Trailer is Better?? #14
I also have had Bias Ply Tires that were 25+ years old on an old car hauler tilt trailer that I gave to my daughter. I told her husband to change the tires. That was 10 years ago and to this day there is no sidewall checking and my son-in-law said he only uses the trailer to haul hay on back roads and he'll get around to changing them. I'm going to buy new tires and give them to him.
For your information the following link will download a pdf file:
How to Read a Tire Sidewall (North American Market)
Tires are not like they used to be!!
Jim
/ Which 15" Tire Trailer is Better?? #15
Jim
So true. Over on the MH forums someone started the word (now gospel) that big truck tires tires blow out after they get 5 years old (saw it on TV that car tires 5 years old can kill you) so new like tires with 10-20K miles on them are being replaced with tires that sometimes are worse then the old ones they pulled but the tire dealers are making out well.:D
/ Which 15" Tire Trailer is Better?? #16
I have actually had a 2 year old Carlisle that was a spare blow just like that while on the trailer sitting in my drive way. Sounded like a shot gun went off.
Chris
/ Which 15" Tire Trailer is Better?? #17
I don't use trailer tires (ST) because of all the trouble they caused me when I ran my flatdeck trailers/cargo/implement trailers in my construction outfit in a eight state area some years back.
Finally a Goodyear truck tire dealer convinced me to go with all LT tires on all the trailers. Granted we had many 15" LT tire sizes and load ranges available back then. Much different now as not much available.
One of my smaller 16' trailers has two 3500 lb axle and I keep Goodyear Wrangler LT215/75-15 D load range on it. Their rated 2095 lbs X 4 = 8380 lbs of capacity.
I run max sidewall pressure , for several reasons, in all of my trailers if the tires load capacity are close the axle ratings.
Goodyear tire web says this about air pressure in tires used on trailers;
Special Considerations
RV TRAILER TIRES
Unless trying to resolve poor ride quality problems with an RV trailer, it is recommended that trailer tires be inflated to the pressure indicated on the sidewall of the tire. Trailer tires experience significant lateral (side-to-side) loads due to vehicle sway from uneven roads or passing vehicles. Using the inflation pressure engraved on the sidewall will provide optimum load carrying capacity and minimize heat build-up.
/ Which 15" Tire Trailer is Better?? #18
asking which tire is better has got to be about the same as asking whether ford is better than chevy. actually, it's more like asking who makes the best vehicle to drive on the road. there's so many possibilities, and in general, they're all going to be good. sure, there are probably varying degrees of good, but based on so many factors - climate, terrain, weight, driving habits, etc, how can you pick a dead ahead winnner? i've seen so many debates on who makes the best of this or that, and in the end, all you end up with is a bunch of little battles.
just to stir the kettle a little, my trailer uses 7x14.5 tires on dexter mobile home axles. the trailer is a little over 10 years old, and i think i'm almost through my 3rd set of tires. sometimes they say "for mobile home use only" and sometimes they don't. i've had the discussion with the state police commercial vehicle enforcement division, and they are legal, and i find them to be perfectly safe and capable. i'm sure there are tons who will say otherwise, but i've seen commercial tires and axles that failed, but to date, mine haven't yet.
buy something capable of carrying the load you need, and it will probably work fine. maybe somethine else will work better for you, but it will be hard to tell unless you try both. it's all about what you feel comfortable with. checking and maintaining your equipment is as important, if not more important than trying to buy the best.
/ Which 15" Tire Trailer is Better?? #19
Good points on looking at what a tire can carry than brands. One load range over the Min value I think is the best way to go.
Yes that can require a lot of looking when it is for a 15" rim. Name brands are not a factor often when looking for the "best" trailer tire.
/ Which 15" Tire Trailer is Better?? #20
Not trying to change the subject to much, i am having a trailer built and found out today what brand of tires they installing on the trailer, now i am having 12K axles installed, tires are Trailfinder. St 235 80 16 radial, any body have good luck or bad luck with these tires, hope they are not the worst on the market, i know there not the best, do to i can buy the tire and rim for $165.00. Thanks guys.
1999 Thompson H3 S/A Towable Vacuum Water Pump (A59228)
1999 Thompson H3...
CAT D8 (A58214)
CAT D8 (A58214)
2012 Jeep Compass 4WD SUV (A59231)
2012 Jeep Compass...
Agri-X 5' 3pt Mower (A53317)
Agri-X 5' 3pt...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
CAT 289D3 (A58214)
CAT 289D3 (A58214)
