Which 20kw whole house generator would you recommend and why
   / Which 20kw whole house generator would you recommend and why
I also read were you were going to install a DLM module on your air conditioner but I had seen were this transfer switch has a built in module in the panel to handle the AC. What made you decide to add the module? Once again I have enjoyed reading about your project and seeing the great photos, thanks again!
I have not yet routed the AC thermostat wire to the DLM module (the built in one), but I plan to do so at some point.
I wanted to also connect the electric water heater to the DLM module, which will require me purchasing at DLM relay.
   / Which 20kw whole house generator would you recommend and why #112
I would recommend an Izuzu 4 cylinder from Hardy Diesel out in California. I bought one of the "14" kw (really a 16 kw) units and am very happy with it. It starts and runs my 5 ton house a/c, 1-1/2 hp well pump and assorted lights, coffee pot, tv etc. The only concesstion I make is to turn off my water heater which is 5500 watts. A really neat feature of the generator end (Italian make MecC-Alte) is that the voltage regulator will take a 100% overload for 10 seconds which sure helps my a/c get started. It also senses the output voltage from a separate excitation winding instead of the actual output winding. Have had to run on it a few times now with one run lasting 8+hours overnight. Sure was nice to have a/c down here in this hot humid Gulf Coast area near Houston. Good luck to all.
   / Which 20kw whole house generator would you recommend and why #113
hmmm, if im not mistaking, i think you just voided the warranty
There were no "warranty void if removed" seals anywhere, so other than the images I have posted here, should there ever be a warranty issue, how would they be able to tell that someone went inside the unit?
Copper Rooster Weathervane (A57454)
Copper Rooster...
UNUSED FUTURE D39 39" MINI HYD TRENCHER (A58376)
UNUSED FUTURE D39...
2015 DRAGON 130BBL VACUUM TRAILER (A58214)
2015 DRAGON 130BBL...
Jisan Heavy Duty CAT345 72in Excavator Bucket (New/Unused) (A59225)
Jisan Heavy Duty...
Manual coupler, outriggers, 78 bkt, (A59228)
Manual coupler...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57453)
New/Unused AGT...
