Which 6 ft rotary cutter?
   / Which 6 ft rotary cutter? #11
The deck has to be braced because of the torque of the gear box and stump jumper. They can either be braced on top or bottom of the deck.
Yea I understand that it must be braced. I just thought it was a "double deck". Smooth top and bottom with bracing inside. But like I said I have never looked at a smooth top cutter before.
   / Which 6 ft rotary cutter? #12
Some do, I just can't remember which ones, I was reading the specs on one the other day, but since I am not in the market, I didn't pay that much attention to the brand or model, may have been a Woods bat wing; just don't remember.
   / Which 6 ft rotary cutter? #13
The Landpride RCR2672 is a very good choice, a lot of cutter for the money. I have one that I use commercially and it has been VERY tough.
John
   / Which 6 ft rotary cutter? #14
Kodiak is another unit to look at.
idaho2
   / Which 6 ft rotary cutter? #15
I called Land Pride today and told that both the RCF 2672 and RCF 2772 have smooth undersides to it. I asked how is that possible as the 2772 has a smooth top. He said the bracing is actually sandwiched in between the too surfaces.
   / Which 6 ft rotary cutter? #16
I chose to get the older LP 1860 with the braceing on top over the 2060 with the smooth top. I don't see how they can say there is bracing sandwiched between the top and underside as the 2060 weighs 19 pounds LESS than the older 1860. If they do have a "double deck" design its got to be thinner steel. Also since you can't "get in there" to clean it or make sure it's dry isn't a double deck design more prone to rust issues as moisture will find its way between the decks somehow. It looks like a solutioin to a problem that is going to end up a bigger problem than it was trying to solve. But I'm just a old geezer dag nab it, don't like them newfangled cutters...:grumpy:
   / Which 6 ft rotary cutter? #17
I agree, I have researched and am down to the RCR2672 or the RCF2772 the smooth is 26 lbs heavier I would rather get out the welder to reinforce a frame member if I found Crack or Break if it is Sandwiched inside you would never know it was Broken till it was REALLY BROKE
   / Which 6 ft rotary cutter? #18
Thanks for the help. Think I'm going with the Land Pride RCR 2672 for the smooth under deck.
graborn How do you like the RCR2672 I am thinking about getting the same for my Kubota M5140 pto is 46 hp. How does your tractor handle your mower and What size and Type of stuff and you mowing Thanks........Bill
WE DO NOT GUARENTEE HOURS UNLESS WE SAY SO!!! (A50774)
WE DO NOT...
2025 Safety Basket Forklift Attachment (A50322)
2025 Safety Basket...
PALLET OF PIPE CLAMPS (A50854)
PALLET OF PIPE...
LOT LOCATIONS (A51222)
2021 Cat D5 LGP Dozer (RIDE AND DRIVE) (A50774)
2021 Cat D5 LGP...
2019 RBR Venturi 380 (A51039)
2019 RBR Venturi...
