Which box blade for a B7510 with turf tires?
   / Which box blade for a B7510 with turf tires? #1
Rod in Forfar
Platinum Member
Forfar, Ontario, Canada
1960 Massey Ferguson 35 (Perkins), 1995 TAFE 35DI, 1980 Bolens G174, 2005 Kubota B7510, 2020 Kioti Mechron 2200ps UTV Troy-Bilt Horse 2 1988 Case IH 255 4WD with loader and cab
I have the price sheet before me and I need some input before I pull the trigger on a purchase. Candidates are a lightweight 4', a lightweight 5', a hd 5' and a hd 6' which I would use with my 35 hp 2WD loader tractor.
The task is to shape sand fill and distribute topsoil on a 250' X 150' lakeshore lot which has some slopes I wouldn't mow across. The high-tech tile-bed pads and septic tank are awkwardly located, and I'll have to excavate about a foot of silt from runoff next to a wall of windows, under a deck (8' to posts; about 8' high). If I could manage it, I'd like to excavate an area below the deck and continue a little ditch through some stony topsoil to facilitate drainage, then import washed stone to build up a pad beneath the deck which will help get rid of the water.
Whatever we can't do with the little tractors will be a pick and shovel job.
Personally, I'm leaning toward the smallest box blade for ease of use around the deck. The dealer suggested a 5' for the B7510, though he didn't make a big deal about the HD model. I like the construction of the heavier one much better than the light one.
I have three suitcase weights I alternate between my Bolens G174 and the Kubota.
So I'd appreciate your opinions on which box blade I should buy. Money's not that big a deal: the home owner will buy it in return for use of the tractor.
If you have a B-series Kubota and a box blade, what size is it?
Thanks,
Rod in Forfar
   / Which box blade for a B7510 with turf tires? #2
A 4' is the best fit for the 7510. You'll run out of traction with it loaded up. What is the part about a 35 HP tractor? Will the box blade be used on another tractor too?
Too late. I bought a 5', then ended up using it on my 17 hp Bolens/Iseki G174 with tire chains on the rears to cope with the mud on this construction site. It's doing the job, though at a glacial pace.
2025 Swict 72in Bucket Skid Steer Attachment (A46683)
2025 Swict 72in...
2009 PETERBILT 386 FLAT TOP SLEEPER (INOPERABLE) (A47001)
2009 PETERBILT 386...
Massey Ferguson 25 Disc (A47809)
Massey Ferguson 25...
2006 SAND  SEPARATOR (A47001)
2006 SAND...
Kivel Dual Prong Bale Spear (A47809)
Kivel Dual Prong...
2011 SAND SEPARATOR (A47001)
2011 SAND...
