Which fuel?
/ Which fuel?
Hi,
I don't know much about the law...
But I do know if my neighbor can burn diesel in his stove to heat his home, and run his car on on the road using natural gas, then I am not going to worry about feeling guilty because I heat my home with natural gas and burn off road fuel in my tractor!
Bill in Pgh, PA
/ Which fuel? #13
I am paying a whopping $1.19 a gallon for off-road diesel recently (versus $1.05 during the summer). The extreme cold weather has jacked up the price ... it is just home heating oil that is dyed red color). It is still about 35c a gallon cheaper than on-road diesel fuel. /forums/images/graemlins/wink.gif
/ Which fuel? #14
Off road diesel. at $1.00 to 1.15 @ gallon i will run it. buy some diesel cans and buy a extra 6 gallons to make your trip worth it.
/ Which fuel? #15
I have 7 of the 5-gallon plastic fuel cans at home, I refill every time I am down to the last 2. So I buy 25 gallons worth at a time. I stop by there maybe 3 times a year.
For fellow tractor friends in S. New Hampshire: I get mine at Ciardelli's in Milford, NH. They have a fuel pump for off road fuel. They can't be making too much money on it, but it is a courtesy for their customers. I have never had a problem with fuel there. I believe it is a lot better than the winter blend of on-road diesel fuel at a regular gas station, which is cut with kerosine. The off-road is pure #2 fuel oil, a/k/a home heating oil.
In the winter I add some diesel additive made by Gunk to keep the fuel from gelling, never had a problem with that either. I have taken it out in below zero weather, always starts right up after 5 seconds on the glow plug. But I always let it warm up to operating temperature before I operate the tractor. Getting very close to 150 hours on the BX2200, I hope we are graced with a bit of warmer weather to do the oil change. /forums/images/graemlins/tongue.gif
/ Which fuel? #16
The on-road/off-road tax deal is a big issue and can cost thousands in fines if you screw up--------but-----let me offer some advice. Bite the bullet and search for some 47 cetane on-road fuel. Add the recommended amount of Power Service additive, and you'll think you've gotten a new tractor!! /forums/images/graemlins/shocked.gif Less smoke, better starting, smoother idle, more power. It's worth the extra $0.20 or so per gallon, but I only burn about 20 gallons per year.
Good luck.
Brian
/ Which fuel? #17
Really no way to screw up if you are running the off-road fuel in machinery. You are legal to run machinery on roads with off-road fuel. The only time you get into trouble with off-road fuel is in a pick-up or a truck that you run on public roads.
/ Which fuel?
My Kubota manual says to run #2 diesel in the tractor. Is #2 what comes out of the autofuel tank at the service station or something else? The manual indicates that it is a lower grade of fuel intended for off road use but I'm not so sure about that...
/ Which fuel? #19
My local gas station has a big #2 on the diesel pump. /forums/images/graemlins/wink.gif
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A61307)
2023 Unverferth...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
2025 14ft. Bi-Parting Driveway Gate (A59231)
2025 14ft...
2019 CHEVROLET SILVERADO 1500 CREW CAB TRUCK (A59823)
2019 CHEVROLET...
Land Pride RCR1260 (A53317)
Land Pride RCR1260...
2005 JLG BOOM LIFT (A59228)
2005 JLG BOOM LIFT...
