roma3112
Folks
I finally got to changing my front axle fluid in my bx24. It has about 1oo hrs on it and since i had a fresh 2gal pale of sudt that was my project for yesterday. Well I did everything exactly as I should with the bleeders ect, the fluid level is stable and within specs. The thing I noticed is that now when i put the unit into 4wd I can kind of hear the gearbox whirling noise. I don't bean a noise like something is wrong inside it seems to be just the normal noise from a spinning gearbox. The problem is that I never heard this before the fluid change, I am guessing the factory had 75w/90 fluid in there?
Now my question, I use the 4wd quite a bit because currently I am doing dirt work leveling off my yard which will last some time. Have any of you folks noticed anything similar? I know the factory says either sudt or 75w/90 but I don't know what I should do now should I drain the sudt out and go get fresh 75w/90 or just leave it. Are there any benefits to either the thicker or thinner oil? I am in the northeast so we do get snow, but it's not like I am using the machine in a very cold climate. Any opinions / experiences would be welcome.
thanks
john
thanks
john
