Which one ck20hst or ck25hst or ck30hst?
   / Which one ck20hst or ck25hst or ck30hst? #61
Round bales: As they say, 'it depends'. It surely won't handle the big bales they feed to walking hamburgers. The bales we use for horses are not as big, equivalent to about 10 square bales. I can get them up on their side and roll them around with my 1 manpower shoulder, so I don't expect too much trouble. I move them with a bucket mounted spear all the time with a JD 4610, which of course is a much bigger tractor.
Moving bales won't be the normal purpose for this tractor, it's for snow removal, landscaping, trenching, moving trailers, lawn rolling, spraying etc. which is why I'm looking to stay pretty small.
   / Which one ck20hst or ck25hst or ck30hst? #62
I've moved plenty of 'rounds with my ck30 w/Woods 1012 FEL no problem lifting 'em over 5'. My 30 has the Woods 1012 FEL w/QA and I used my pallet forks to pick/move the bales. I realize the Woods has a bit more capacity than the kl130 but I would think that it might be able to handle it, ........ or see if your dealer carries Woods implements. I personally know the ck30 is up to it.
   / Which one ck20hst or ck25hst or ck30hst? #63
You guys are educating me. I always thought round bales were those huge things left in the middle of hayfields. I googled it and found the following: "Large round bales will weigh 500 to 3,000 pounds with dimensions varying with the baler manufacturer and model. Usually the bales are 5 to 7 feet long and 5 to 7 feet in diameter. Bale weight depends not only on dimensions but also on the type and quality of hay baled."
I'm sure even a CK20 could lift the 500lb size into a pickup bed but again you'd need some sort of QA system in order to efficiently and safely use a bale spear or forks. Not sure it would be safe to use bucket mounted forks with no backplate to keep those things from rolling back over you if you curled a bit too much.
   / Which one ck20hst or ck25hst or ck30hst? #64
Reviving an old but good thread - note this is an old thread.
I too am in the market for a similar sized machine.
Has there been any major changes in the last two years?
Bill you are going to be dangeriously overloaded with either the CK25 or 30.
The CK30-Gear tractor weights 3042#.
The CK30-HST tractor weighs 3055#.
The KL-130 loader weighs 770#.
So the tractor and the loader will weigh roughly 3820#.
Assume roughly 500# up to 800# for the brush cutter
Assume roughly 500# up to 700# for the tiller
Assume roughly 500# for the liquid filled tires.
Assume roughly 80# for a full tank of diesel in the tractor
Assume roughly 200# for 6 chains and binders to comply with DOT standards
Assume the trailer, which is rated for 7000# has an empty weight of 1600# (presumes a 16' trailer) or 2000# (presumes a 20' trailer).
If you have an 1800# (18') trailer, you are up to 3580# in weight without the tractor. That leaves you 3420# of capacity for the tractor, loader & backhoe. (Tiller + Brush Cutter were both calculated at only 500# each, so it is very possible the total combined weight could = 4080#)
3580 (trailer, implements, fluids) + 3820 (tractor) = 7400# without the backhoe.
You are over the rated trailer capcity by 400# without the backhoe. Add a backhoe, which weighs over 1000# (when you incude the weight of the bucket) and you are now 1400# over the trailer capacity and and 700# over the truck's capacity. Also consider that a CK30 tractor, loader, backhoe won't fit on an 18' trailer so step up to a 20' trailer and your trailer weight also goes up about 200#, which now means that your total weight is 1600# pounds over your trailer capacity (you are already at 8600# on a 7000# trailer ), and # over the truck's tow capacity.
Now if you are in the landscaping business, then it is reasonable to assume you will have shovels, tools, extra fuel cans, drinking water, and other things on the trailer. You will easily be at 9500# (and could be up to 10,000# if your implements weigh over 500# each) on a 7000# trailer.
  • Now if anyone tells you a 7000# trailer can safely hold that, they are a liar.
  • If anyone tells you your truck can safely tow that, they are a liar.
  • If you think your truck's transmission and brakes will hold up for the long term, you are mistaken.
  • You are also in violation of commercial towing laws and better hope the DOT inspectors don't grab you because they could possibly impound your whole rig.
BTW . . .
if you downsized to a CK20, a 48" rotary cutter, a 48" tiller then your weights will be roughly:
  • 1675# = tractor: 1193# + 400# for liquid fill + 80# fuel (in the tractor's fuel tank)
  • 650# = loader
  • 885# = backhoe: 785# hoe + 100# bucket
  • 400# = tiller: 400# to 600#
  • 400# = cutter: 400# to 650#
  • 200# = chains and binders
  • 1800# = approximate raw trailer weight, 18' trailer
  • Add another 400# for additional fuel, tools, water, supplies
  • 6410# = total combined weight of CK20, trailer + supplies
Using the CK20 with your truck & trailer gives you a modest amount of safety capacity. Even if you used a heavy duty tiller + HD rotary cutter, your total weight would likely be in the range of 6850#. Not much margin for error here, but still just under your legal maximum capacity.
If you need to use a larger rotary cutter and larger tiller than the CK20's PTO HP can manage, then you better look at a different brand that offers a lighter weight tractor with greater engine/PTO horsepower. A Kubota B7800 is a 30hp tractor that weighs a little more than the CK20 and powers the same size implements as the CK30. It is a basic machine without some of the nice features the CK offers, it has lower lift capacity than the CK30 too, but the tractor weighs about 1741# (add ~450# for fluid fill and you are under 2200# for the tractor) you will be pushing your trailer capacity but still stay under 7000# with a B7800 configured as the CK20 is configured.
The other option is to move up to a bigger truck and bigger trailer to haul a CK25/30 tractor.
   / Which one ck20hst or ck25hst or ck30hst? #65
The 20 is now a 22s with 2 more HP, same thing, the 25 is now a 27, again with 2 more HP. The 30 has not changed to my knowledge. Change in engines was emission related for the most part.
   / Which one ck20hst or ck25hst or ck30hst? #66
A big congrats and welcome to the pack to you Xtremesvc! I think for your business you made the right choice, the CK20 is a brutus of a machine and small enough for yard work. For the once in a blue moon you need a monster machine rent it.
CurtC, be careful with the rounds. I went through the exact same process as you are about a year and ago and finally got the CK30 which still is actually too small for rounds in most cases. I can (safely) lift and move "light" rounds (maybe 500#) but I do so very carefully. I would be scared to use a tractor that was any smaller because we have slopes and ruts and being even a bit off level with the FEL up and loaded way out front with a bale is sketchy business. And make sure you use ballast on the back. It makes an enormous difference and plain feels better.
   / Which one ck20hst or ck25hst or ck30hst? #67
Umm jimmyj - did you notice that all the posts before mine were back in 2007, about the time you joined?
I just dug it up because it has some good weight statistics and I'm trying to decide beween the same two machine and a Kubota.
   / Which one ck20hst or ck25hst or ck30hst? #68
Oh crud. How embarassing!!!:eek:
I wondered why I had not seen that post before.
2020 JOHN DEERE 7R210 LOT NUMBER 48 (A53084)
2020 JOHN DEERE...
2005 Hino 268 Truck, VIN # JHBNE8JTX51S10984 (A51572)
2005 Hino 268...
Wolverine BC-13-72W, 72" Skid Steer Brush Cutter (A52384)
Wolverine...
2016 Isuzu NPR Landscape Dump Truck (A51692)
2016 Isuzu NPR...
2023 Stryker GN3614 36ft. 5 Ton T/A Gooseneck Flatbed Equipment Trailer (A51691)
2023 Stryker...
Single Axle Rear Truck Frame (A51692)
Single Axle Rear...
