Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches??
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
My new to me tractor has 39, 40, or 41 engine horsepower,,, depending on where you look.
The tractor is rated at 32 PTO HP.
I am not worried about trimming,, we have smaller machines for that,,,
So far, I have looked at only Woods,, the "PRD" mowers look much nicer than the "RD" series,,
but, is it $1,000 more?
The mower will be used for just flat out getting about 10 acres mowed. Sometimes as much as 18 acres.
The 72" would work,, but, I found a used 84" RD8400 for only $1100.
There seems to be VERY little price difference between new 72" and 90" mowers.
If I am getting a new one,, it seems the bigger one would make more sense.
I doubt that cut quality of any of them will disapoint me,, this is not golf course quality lawn,,,
I am a little worried about the bigger mowers tearing the gauge wheels off sooner than the lighter mower.
I believe the heaviest mower is right at ~900 pounds.
Hmmmm,,,,, Help me spend some money,,, wisely for a change,,, :laughing:
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #2
I run an 84" rear discharge on my 28 PTO HP tractor with no problem.
My vote would be for at least 84" mower.
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #3
I ran a 84" Befco on 28hp without issue. It weighs 690 lbs.
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #4
Provided the tractor can handle the physical size....
Bigger mower and going slower dont take any more power than a small mower going faster. How fast you can mow in terms of acres per hour....is based on your horsepower not mower size.
So the key difference is gonna be ride quality.
IE:....6' mower mowing at 4 MPH and a 8' mower mowing at 3 MPH require the same HP to operate.....will get done in the same amount of time....but slower is gonna be a smoother ride.
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #5
Aren't you still using the JD390 you bought????????
The JD390 is used for "bush hog" type work,, never on a lawn,,,
it never had any kind of quality of cut that a RFM mower gives,,,
Hmmmmm I wonder what would happen if I hooked the JD390 to the JD 4105??
I think the front end would get awful "light"!!?? :eek:
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #7
Yup, big & slow is the way to go. Unless you need the maneuverability.
Yea, I need zero manuverability,, the areas are big,, and open,,
I LIKE the idea of slow,,, :thumbsup:
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #9
Perhaps a small ten foot or so pull-type batwing would work well.
   / Which RFM? 32 PTO HP,,,, 6 Foot, 7 Foot, or 90 Inches?? #10
I have a Kubota L3710 (35-ish PTO hp) and a Bush Hog ATH900 finish mower.
As long as your tractor is heavy enough, wider is better. I did run this mower with my NH TC30 and it was super sketchy when carrying it over rough or sloped terrain. The tail wagged the dog at times. My Grand L handles it very well.
As you your concerns about the weight, the 90-inch mower is built like a tank compared to the narrower models. I think I've had better luck with the heavier, stouter machine than I would with a smaller one.
One point - I've found that second hand 90-inch mowers can be the same price as 6-footers. I have been tempted by 11 to 12 foot batwing finish mowers a few times. Missed one this winter that needed one spindle rebuilt for less than 2 grand. If I had 18 acres to mow, I'd go as wide as I could carry / store / run.
2023 New Holland CR10.90 Combine - 332 Engine Hours - 244 Separator Hours (A53473)
2023 New Holland...
Wright Sentar (A50120)
2018 Taylor-Dunn BigFoot B5-440-36 Electric Utility Cart (A50324)
2018 Taylor-Dunn...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
ROLL OFF BOX (A53843)
1998 Ford F800 2,000 Gallon Water Truck (A52377)
1998 Ford F800...
