Which Stick Welder for a New Welder?
   / Which Stick Welder for a New Welder? #91
For what it's worth - I just ordered an Everlast PA 140ST today. Mark was very helpful and answered a lot of questions.
   / Which Stick Welder for a New Welder? #92
Good luck with you new welder.On the bright side you won't get a hernia moving it around!
   / Which Stick Welder for a New Welder? #93
I wish there were such a thing as a stick/mig/plasma unit but Mark says it isn't technologically possible without the price being off the charts.
Ian
   / Which Stick Welder for a New Welder? #94
Ian
what about getting a TIG/stick/plasma, and hooking up a voltage sensing wire feeder, like a LN-25 to the stick output, you would have mig/stick/tig/plasma.
   / Which Stick Welder for a New Welder? #95
Well technically you wouldn't have Mig. You'd have a wire feed but not GMAW. Generally Mig runs on CV, not CC.
But I read an article years ago, where the author had good luck with 1/16-inch bare wire, with 75 / 25 gas running on CC. :confused2: :laughing:
   / Which Stick Welder for a New Welder? #96
So would you have to use flux core?
   / Which Stick Welder for a New Welder? #97
You can use flux core self shielded, I've also read where there are flux core gas shielded wires that can run on CC.
Since about the mid 1990's for FEMA, and other seismic code work only CV machines are allowed. But you're a few years away from worrying about code work.;)
Friend of mine came over and looked at the wiring in my metal building. There's a 50 amp breaker in the main box that runs to the metal building. My friend said the wires coming in to the subpanel in the metal building were big enough to simply put in a circuit breaker (50amp iirc) and then run a dedicated welding circuit and mount the plug where I needed it.
Still haven't found a tombstone or comparable miller since my original post.:(
   / Which Stick Welder for a New Welder? #100
Someone was advertizing a welder on the local radio station for $40. Of course you don't know what kind of condition it was in.
Ian
1988 Kenworth W900B Dump Truck with 3406B CAT (A53473)
1988 Kenworth...
CFG Industrial SAII100 (A50123)
CFG Industrial...
Toro Workman 200 Sprayer Cart (A50324)
Toro Workman 200...
2025 CFG Industrial QK18R (A50123)
2025 CFG...
2018 Bobcat T595 (A47384)
2018 Bobcat T595...
2009 40ft High Cube Refrigerated Storage Container (A51692)
2009 40ft High...
