Which used ZD model ?
   / Which used ZD model ? #21
Early ZD's did have problems with mowing side hills with the hydro's. Kubota did offer a kit at the time to increase the oil reservoirs to eliminate the problem and it seems to work. Hour limits on many of them are well beyond many, we have a ZD323/60 over 7,000 hours and we have more in the 4,000 to 6,000 hour range professionally used with no component failures.
   / Which used ZD model ? #22
Have a 331 with 3000 hrs. A great machine and still runs like new.
   / Which used ZD model ? #23
Do you have a 72” cut, how do you like it on the hills? Considering a used one with 1200 hrs.
Thanks,
Matt
   / Which used ZD model ? #24
   / Which used ZD model ? #25
I bought this ZD21 used in June '09, found that it had both blade bolts on the outside spindles stripped, replace those and put on a new belt. Couple of years ago, put tubes in the front tires. Didn't realize i've had it 9 years already. Oil changes and a splash of diesel now and then is all it has needed.
https://www.tractorbynet.com/forums/files/kubota-buying-pricing/132807d1245436080-zd21-mower1-jpg
I’m looking at a 331 with 1240 hrs, looks really clean but even with it being a diesel seems high but will likely buy if I can get my price.
Nice looking ZD21!
   / Which used ZD model ? #26
I paid $9800 for my zd331 72” mower last year with 500h. The larger deck saves me 60 hours of seat time each year compared to my zd326 with 60” deck.
   / Which used ZD model ? #27
They are asking $7500 for this one.
   / Which used ZD model ? #28
Assuming there are no issues, imho that is a very good price (for you).
   / Which used ZD model ? #29
   / Which used ZD model ? #30
At least some of the ZD21's had weak trasmissions. I have a high hour ZD326 that been a great machine with normal maintenance and one starter. I bought the ZD331 with 400h, and it had an aggravating fuel delivery problem that was solved with an additional filter and lift pump.
My 331 is significantly faster than the 326, and combined with the 72" deck it is hard to beat.
How do you know if the pump upgrade has taken place or would need it performed?
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A56129)
2018 FREIGHTLINER...
2018 Ford Fusion Hybrid Sedan (A55758)
2018 Ford Fusion...
2014 CATERPILLAR 826G LANDFILL COMPACTOR (A51406)
2014 CATERPILLAR...
2003 Ford E-450 16ft Reefer Box Truck (A55788)
2003 Ford E-450...
BRAKE DRUM HANDLER (A55745)
BRAKE DRUM HANDLER...
Gehl V400 (A47477)
Gehl V400 (A47477)
