White Lithium Grease OK?
/ White Lithium Grease OK? #1
KennK
NE Wisconsin
John Deere 3320
The only Grade #2 grease my local Home Depot carries is Plews LubriMatic White Lithium Grease.
Is that OK to use on my new JD 3320 tractor w/ the 300CX loader?
The closest JD dealer is far enough away to make buy JD-brand grease a pain.
/ White Lithium Grease OK? #3
I think I would try Walmart or an auto parts store. You need a high pressure type. It's about $2.50 at Walmart. You will be greasing it every 10 hrs so you may want to get several tubes to have some on hand.
/ White Lithium Grease OK? #4
/ White Lithium Grease OK? #5
I would not use the WL grease in a pressure zerk type of application unless the application specifically called for it. Usually the GP moly grease is fine.
Ben
/ White Lithium Grease OK? #6
Ben
/ White Lithium Grease OK? #7
I like the lithium based general purpose chassis grease with the EP or extreme pressure rating. I go for the red color because it's fun. This EP grease isn't light and buttery but just about as thick as peanut butter.
I overgrease, it makes a mess, but too much beats too little.
/ White Lithium Grease OK? #8
/ White Lithium Grease OK? #9
</font><font color="blueclass=small">( The only Grade #2 grease my local Home Depot carries is Plews LubriMatic White Lithium Grease. )</font>
I went in search of grease recently too. Stopped in to the local HD all I found was the dark gray LubriPlate Multi-Purpose Lithium Grease. It is rated NLGI Grade #1-1/2 w/ a 350*F Dropping Point, Timken OK Load Rating not noted, for $2.19/cartridge. I passed. Wally's had dark gray SuperTech Moly-Lithium Extreme Pressure rated NLGI Grade #2 w/ a 350*F Dropping Point, 45lb Timken OK Load Rating for $2.12/cartridge. I understand both are compatible for mixing with Lithium 12-HydroxyStearate bases and, since I want to use only one grease for both chassis and bearing use, I chose the ML-EP Grade #2 Grease.
The term "white lithium" does cause some confusion for me though. My new B7610 came with fresh dollops of white grease oozing from ALL zerk fittings, chassis, bearing, FEL, whatever. Naturally I assumed it was a white, not dark gray, Lithium 12-HydroxyStearate based grease, and NOT a synthetic base. I didn't think that color was the single distinguishing feature that signified a soap or synthethic base for greases. At least, I sure as heck hope not... /forums/images/graemlins/tongue.gif
/ White Lithium Grease OK? #10
/ White Lithium Grease OK? #11
</font><font color="blue" class="small">( I go for the red color because it's fun. )</font>
It is hard to argue that one. /forums/images/graemlins/grin.gif
The grease I use is a dark gray and it always ends up getting on my shirt and ruining it. I might need to switch to a light color of grease or start buying dark gray shirts! /forums/images/graemlins/grin.gif
/ White Lithium Grease OK? #12
/ White Lithium Grease OK? #13
Sounds like we have a similar problem. The grease does not stay where you put it. I'd swear that stuff jumps off the tractor at you.
/ White Lithium Grease OK? #14
Attention (A57148)
Attention (A57148)
2024 CATERPILLAR 305CR EXCAVATOR (A60429)
2024 CATERPILLAR...
2021 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A59230)
2021 Chevrolet...
HUSTLER RAPTOR SD ZERO TURN LAWNMOWER (A60430)
HUSTLER RAPTOR SD...
2013 CATERPILLAR 308ECR EXCAVATOR (A60429)
2013 CATERPILLAR...
3-Gang Reel Mower Pull-Behind Tractor Attachment (A59228)
3-Gang Reel Mower...
