Who actually makes the tractor and whose engine and transmission does it carry?
   / Who actually makes the tractor and whose engine and transmission does it carry? #1
Reddogs
John Deere 790 / Kubota L3301
I was looking at the LS tractors at the dealer, and noticed it had Mitsubishi engines, but now I am told the LS uses Yanmar, Mitsubishi and LS engines depending on model. Now I know my John Deere is basically a Yanmar drivetrain with engine and transmission, but the FEL and Backhoe are to my understanding made by John Deere. The Kubota is a Japanese brand, and yet to my understanding the drivetrain with engine and transmission along with the FEL and Backhoe are made in the US by Kubota. Who and where is the real manufacturer of the tractors, and is the whole tractor made by them or the drivetrain with engine and transmission 'farmed out' so to say to another manufacturer? Or do some just get it from whoever, like they built the Jeep in WWII?
   / Who actually makes the tractor and whose engine and transmission does it carry? #2
Are there any photos of these companies actually making there own products, other than assembly? I worked since 1990 in sheetmetal jobshops, and could see a lot of the outsourced parts and subassemblies used on others assembly lines. But we were certainly not Cat, Case, Deere, Komatsu, etc, etc. It doesn't take much for purchasing and engineering to put together and submit parts documents for outside quoting and eventually outsourcing. And, other than cost savings internally for those companies, what would be the difference if parts were outsourced to their specifications and qc requirements, or if they were done internally to their specifications and qc requirements.
   / Who actually makes the tractor and whose engine and transmission does it carry? #3
Yanmar makes engines in only the small deere series, not sure what other engines are used. Yes Kubota moved a significant portion of its manufacturing to US soil. I don't think any of the big manufactures are getting their engines or transmissions from "whoever" when they farm them out, it's a pretty deliberate process. Also keep in mind companies like Kubota and Yanmar started out making engines and just decided to start their own tractors where as some other companies started with tractors and now may or may not make the entire tractor. I would have no fear with any of the big names, once you go lower tier tractors or gray market that's when I'd be a lot more concerned about who made the parts (like cabelas tractors...shudder).
   / Who actually makes the tractor and whose engine and transmission does it carry? #4
John Deere started out making plows, if I recall correctly. Case was also an implement manufacturer first, I believe.
   / Who actually makes the tractor and whose engine and transmission does it carry? #5
Yep, it is complicated but Ford, Toyota etc don't make car parts either.
There are Tier 1 and Tier 2 suppliers that spend millions to get just a chance to quote on parts in the auto world.
Suppliers get hammered if a defect reaches a consumer and a report card is issued annually. It doesn't take much to get a failing grade and if you have reoccurring issues, you will not get to quote on future work for a specified time. That is in the auto world and obviously, tractors are not in that league. At least not yet.
It's not pass it along to 'whoever' but there is a common process that makes it hard for us to keep up.
I worked in manuf. nearly 40 years and typically saw 3 phases of the production life cycle.
  1. Start of production - design flaws, poor vendors, and assembly defects are identified and corrected
  2. Much time and effort are spent on improving the quality of parts and the finished product to eliminate bad parts from being made much less leaving the factory.
  3. With defects low, quality and engineering teams are disbanded. Those who are not reassigned to other product lines are left to find ways to make it cheaper.
That is a long explanation but you can see why phases 1 and 3 cause change and why I try to buy during the phase 2 era.
   / Who actually makes the tractor and whose engine and transmission does it carry? #6
Actually, Kubota started out making weaving machines, that produced cloth. The whole history is on their website somewhere.
   / Who actually makes the tractor and whose engine and transmission does it carry? #7
Kubota has a time lapse video on YouTube assembling a Kubota engine. No automation. Assembled by 2 people on a rotating stand. Similar to assembling in one’s own workshop if a parts kit is available. Similar to what I saw at the Perkins plant in the UK when they began producing Shabura engine under license and labeling them Caterpillar or Perkins. I’ve always considered assembled vs manufactured as 2 different things. Where are the component parts sourced? I visited an aluminum foundry in the small town of Lone Jack, MO, and saw them casting, and machining, engine blocks for multiple manufacturers. It was a surprise as I thought engine block production was sourced in house and the other components came from sources around the world, but this was when most blocks were cast iron and only specialty engines were aluminum.
   / Who actually makes the tractor and whose engine and transmission does it carry? #8
I have a Farmtrac that was made by LS for Farmtrac with a Mitsubishi engine in South Korea, they made all the compact tractor models starting with the 270, 300, 320, 360 and the 390 and I believe all of them had the Mitsubishi engines, they also made the same line of tractors for Montana, which were identical other than color and the badging that they put on them, I said all that to say that LS was making tractors for other manufacturers long before I ever saw their own products here in the U.S.
Well it seems Yanmar makes a good deal of them for a vast number of John Deere models, does John Deere have a plant that makes the engines on the larger end?
   / Who actually makes the tractor and whose engine and transmission does it carry? #10
Like I said, small deere series. Not sure what percentage of their sales that is but I bet it's fairly small dollar wise. But again, so what? Yanmar makes a great engine and Deere makes a lot of good products.
   / Who actually makes the tractor and whose engine and transmission does it carry? #11
Will drive you crazy trying to figure that out;I know the most American made car is a Honda;and truck is a Toyota!
I believe Kubota at least makes all the own parts.
   / Who actually makes the tractor and whose engine and transmission does it carry? #12
Actually, Kubota sells re-bagged tractors too, so they don't make ALL of their own parts.
SR
   / Who actually makes the tractor and whose engine and transmission does it carry? #13
I've never understood the fascination with trying to track down all the details of what comes from where in a product. I just evaluate products based on their features, cost/value and the reputation of the manufacturer. If I trust JD to make a good product I don't care whether they made the engine themselves or bought it from Yanmar. And for the idea of trying to make sure everything is 'from' USA I just don't think that's possible with pretty much any semi-complicated product these days. If it has multiple parts and systems it is pretty likely some of them are not from the USA.
As mentioned above, you'll drive yourself nutty trying to parse through it all. But if that's what makes you tick then go for it. It's just not worth it for me.
   / Who actually makes the tractor and whose engine and transmission does it carry? #14
If you look at the Deere website, they list the engines for each model. The larger Hp models (about 60+ hp) list the engines as JD, not Yanmar. IDK where they build them, but I assume in the US.
Easy, I know the quality of a Yanmar engine and transmission, and the little things that make it easy to use and work with, and I would like, much my toyota, keep that. Better what you know than be unpleasantly surprised..
   / Who actually makes the tractor and whose engine and transmission does it carry? #17
LS, and by association, New Holland, do use different makers' engines on different models. If you buy a Kubota, you'll get a Kubota engine. Deere compacts use Yanmar, I think, exclusively, and of course, Yanmar uses their own. It does make choosing a tractor even more complex, even though I doubt anyone here knows the strengths and weaknesses of different diesel engines.
It's enough to make you yearn for simpler times.
   / Who actually makes the tractor and whose engine and transmission does it carry? #19
Reference one rebadged Kubota tractor. I’m not aware of any.
Kubota's big M8 series is a Versatile made in Canada.
   / Who actually makes the tractor and whose engine and transmission does it carry? #20
Saw a youtube video with a guy talking about his new TYM tractor and he said he didn't want any grief about having a Korean tractor. Then he showed the tag on his John Deere 5065E , it said assembled in India.
2013 KOMATSU HM400-3 OFF ROAD DUMP TRUCK (A60429)
2013 KOMATSU...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
2017 Ford F-550 Mason Dump Truck w/ Liftgate (A59230)
2017 Ford F-550...
207275 (A52708)
207275 (A52708)
2017 CATERPILLAR 420F2 IT BACKHOE (A60429)
2017 CATERPILLAR...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
