Garandman
Elite Member
- Joined
- Aug 3, 2014
- Messages
- 3,131
- Location
- Mount Sunapee NH / Dorchester, MA
- Tractor
- Kubota L3200 HST
Rolair has a sterling reputation.
A true 2 motor won't start and run on a 110 volt 20 amp circuit.
How many amps does it draw? You don't know if it's REALLY a 2hp motor, until you see how many amps it draws...no matter what the mfg called it.I've got a 2HP motor on an electric logsplitter that runs off a 120 vac circuit with a 20 amp breaker. (It came with a plug with one of the prongs turned sideways, so intended for a higher amperage 120v circuit, but I swapped the plug and have not had a problem). Probably part of the reason it works is the motor does not start up with any sort of load on it. It runs anytime it's plugged in, but only gets a load when I activate the hydraulic valve on the splitter.
