Whose Boxe Blade to get & What Size?
   / Whose Boxe Blade to get & What Size? #11
I built a leveling board that clamps under the BB. My Arps model 350 is six feet wide. The steel reinforced leveling board is seven feet wide. At each end is a "Ski" to keep the BB from digging in. It works very well for smoothing new lawns.
My system works well on 35 hp. tractors.
A good box blade has the hinged rear blade. The hinged blade allows it to dig going either direction. You won't find one at TSC, and it will cost more than the TSC model.
What will the hinged rear do that a dual blade (one for going forward & one for going backward) box will not? Most of the box blades that I have seen have two blades. I do see hinged blade boxes for more $$$.
   / Whose Boxe Blade to get & What Size? #13
This is what I use on my 22 hp Ford 1510 with good results. It's from Tarter gate: 5' Heavy-Duty Hinge Back Box Blade, Weight: 461 lbs.
The big differences are, I'm running anywhere between 500 (empty) to1200 lbs (w/FEL) more weight than the OP's tractor, which is a huge difference, I'll admit; but I'm also running on turfs, so that may make up for some of the weight discrepancy. So far, I've been able to handle it quite nicely with the rippers fully engaged. OTOH, I think we all forgot to ask what kind of tires are on the B9200. :confused: Tires vs. weight???
Very true. Mine has the hinged back, but it doesn't have the ability to lock in place... yet! ;)
Joe
The 3 most important things to make tractor traction are weight, weight and weight ! :laughing:
   / Whose Boxe Blade to get & What Size? #14
The hinged rear blade floats allowing the front blade to cut more material because it is not held up by the rear blade. I know that you can tilt the front to get the back raised up so that it no longer drags, but when you do that you have altered the angle of the front cutting edge and moldboard from the optimum cutting angle that it is designed to work at. Same sort of thing occurs when people tilt their box to get the rippers to dig in deeper, they are changing the designed angle that the rippers are supposed to be at to get the best results.
   / Whose Boxe Blade to get & What Size? #15
Sorry if I'm hijacking the OP's thread, but I thought it would be silly to make a new thread asking the same question. I have a 37hp, 2000 lb. (unballasted and w/o FEL) with a 59" track width, 4WD, R1s front & rear. I was leaning towards a 60" box blade as I think that's all I will be able handle traction wise. This just barely covers the track width of the tractor, but I'm just not sure I will have enough traction to pull a 72" box blade.
What do you guys think?
   / Whose Boxe Blade to get & What Size? #16
Forget about a 72" box, your tractor just does not have enough weight.
   / Whose Boxe Blade to get & What Size? #17
No way you have enough traction to really work a 72" blade with that machine.
I just read the manual on my M59 last night... max rear scraper blade they recommend for that machine is 72", and thats an 8000LB machine with 59 HP.
   / Whose Boxe Blade to get & What Size? #18
I have a slightly larger tractor with a 60" HD United BB. It is just fine. The Countline has a better design for ripper adjustment. You have to get down and dirty to pull the cotter pins on the United, or at least the ones I have seen. I would shop by $$. Either would be fine. At 1700lbs, you will not be able to generate the traction it would take to put tons of stress on the unit. Don't spend a fortune when you don't need to.
   / Whose Boxe Blade to get & What Size? #19
I have read in many threads on this site over the years, where guys will helpfully suggest that you HAVE to cover your tractor wheel tracks with the boxblade. My experience differs.
I bought a 48 inch boxblade for my first CUT, a JD 4100 with 21 Hp. It was wide enough to cover the wheeltrack, and the tractor handled it fairly well. I added weight to the boxblade to help it bite in. I probably had the only 48 inch boxblade that weighed over 700 pounds. I ran that neat little 4100 for several years, did a lot of boxblade work, then sold the 4100 and bought a JD 2520. The 2520 has 26 Hp, and weighed half again as much as the 4100, and was about half a foot wider than the 48" boxblade, which I kept. I started thinking that I was going to have to trade up the boxblade because you know "you have to cover your tracks with it". But while considering it, I started using it 'cause it was still a very effective loader counterweight, and I needed a boxblade. And I noticed something. It really didn't matter that it was narrower than the tractor for the landscaping work I was doing because you remove soil in layers anyway, and it turned out to be a big advantage that it was narrow when simply being used as a loader counterweight. So I kept that little BB. Two years later, because I bought 80 acres of farmland and had heavier work to do, I traded the 2520 for a JD 3720. The 3720 has 44 Hp, weighs a bit over 4000 pounds ballasted, and is 66 inches wide at the back with wheel spacers. Its almost two years old now. And you know what? I am still using that original 48 inch boxblade. Its still heavy enough for effectiveness as a counterweight since I added a whole bunch of wheel weights to the back tractor wheels. And I can pull that small BB like mad with the power and traction I have. Last year I made an asparagras bed. That requires first digging a trench a couple feet deep. I used the boxblade, and it dug real well until was down most of the way and then I couldnt put it any lower because the tractor would not drop into the trench 'cause of course the tractor is wider than the BB. Thats the first time I had any issue. A wider BB would have made the trench too wide anyway, so I would have had to find another way to make the trench if I had a wider BB. Other than that one job, my experience doing driveway maintenance, building site prep, stump removal with scarifier teeth, waterway creation, ditch creation, and similar jobs, all work fine with that same little BB that is now 18 inches narrower than the tractor pulling it.
On the other hand, if you are buying a finishing tool, like a landscape rake, then by all means get one that is wider than your tractor tracks even when fully angled. But the Boxblade is certainly not a finishing tool and in my opinion and experience over 5 years and two tractors that were bigger than the BB I own, you do not need to cover your tracks with a boxblade. In fact, its better if it is smaller and heavier, cause that way the psi on the ground is higher and it does more work, and it always works better as a counterweight if it is as small and heavy as possible.
My 2 cent's worth, good luck.
   / Whose Boxe Blade to get & What Size? #20
Always nice when the voice of experience kicks in. :thumbsup:
2012 Ford F-250 Pickup Truck (A55973)
2012 Ford F-250...
2015 Ford F350 XL (A57148)
2015 Ford F350 XL...
UNUSED X-STAR ACS LOADER BOOM LIFT (A52706)
UNUSED X-STAR ACS...
2019 RAM 5500 Bucket Truck with Versalift VST47 Boom - Cummins Diesel - 4X4 - Automatic (A56438)
2019 RAM 5500...
2008 TEXAS BRAGG 20 UTILITY TRAILER (A55745)
2008 TEXAS BRAGG...
48ft all aluminum feather light wedge trailer (A56436)
48ft all aluminum...
