Why are Zero-Turn Mowers so Expensive?
   / Why are Zero-Turn Mowers so Expensive? #11
stubborn said:
From what little browsing I have done most Zero-Turn Mowers (ZTM) seem to be priced kinda high, at least compared to a "regular" tractor. Home Depot and Lowe's has a Deere and Cub Cadet, both with 38" decks (I think), non mulching (which is what I want) and both machines are priced at $3K. I bought a Cub Cadet LT1050 mulching tractor for $2200 last year.
Are ZTM machines that much more expensive to build? If I did get one it would need to have a 48" (minimum) mulching deck and I would like to not pay more than $2500. I have about 4 acres to mow and lots of it is paths. I found this Husqvarna 48" ZTM at Sears for $3K but that still seems expensive. Maybe it's just me.
Mornin Stubborn,
Take a look at the deal Home Depot has on there Toro Z4200. 42" cut 19hp Kohler Command engine for $2499. If its a first time purchase on HD credit card take off 10% bringing the total price to $2250 plus tax. I was thinking about a 6 ft rear finish mower for my Massey, but the more I think about it the small ZTR makes more sence. I wont have to remove my bushog everytinme I want to cut the lawn ! I believe they offer a 3yr warranty. I believe that machine can mow 1 3/4 acre per hour !
   / Why are Zero-Turn Mowers so Expensive? #12
a cheap one will only give about two years decent service in normal use
Sure hope you're mistaken about how long a cheap one will last, since my cheap Toro is already 6 months over that two year limit.:D So far the only maintenance has been to change oil a couple of times a year, clean the air filter a bit, blow the dust and debris off the whole machine with compressed air after each use, and I just recently put a new spark plug in it; might not have been needed, but I figured after a couple of years it might be a good idea. I do, admittedly, have a small yard to mow, and it sure does that mowing in a hurry, but I also occasionally pull a lawn dethatcher and a lawn sweeper with it.
   / Why are Zero-Turn Mowers so Expensive? #13
Bird,
I know you can always get great service from your machines because of your maintenence and care of them. I think the Toro machine you have has quite good motors and componentry and should give you many more years good service. I suppose it still greatly boils down to maintenence, some luck and how many actual hours go on the machine.
John M
scott_vt said:
Mornin Stubborn,
Thanks for the tip. I just looked at Home Depot and found the Toro Z5000 50" ZTR for $2800. I did not know about the 10% discount when using the HD CC. Alas, as I am near completion of a $12K++ landscaping project a ZTR mower will probably have to wait until next season which is OK b/c by then there should be some nice used models available.
BTW, one thing that is unclear to me: Most ZTRs that I have looked at (on the web) appear to be set up for bagging but I want to mulch. Is it unusual to mulch with a ZTR or are there any drawbacks?
   / Why are Zero-Turn Mowers so Expensive? #15
I did a quick google, "zero turn mulching mower". It appears to me that some companies such as EZ Mark, Dixon, and Areins, sell a conversion kit, not sure they make one for the make and model you are looking at, but perhaps you could do a little looking and/or calling around and see if its available.
Hope that helps...
Lions
Hope that helps...
Lions
Thanks for that info. Actually, after I posted I took a second look at the Toro & Cub Cadet pages and found that they both offer mulching kits.
   / Why are Zero-Turn Mowers so Expensive? #17
When I bought my Toro, I told the dealer I wanting mulching. Whether he changed the blades, I don't know, but I do know he installed the cover that blocked the discharge chute, but delivered the discharge chute with the mower in case I ever change my mind. At any rate, it does a good job of mulching.
   / Why are Zero-Turn Mowers so Expensive? #18
Mornin Bird,
Which model Toro did you end up getting ?
   / Why are Zero-Turn Mowers so Expensive? #19
Scotty, if you click on the link in my first post, it'll take you directly to the model I have. I'm not sure why they apparently call it a Z380 now and called it a 14-38Z when I bought mine. I don't see any changes; 14 hp Briggs, 38" cut. Even the price is the same, although my dealer knocked $200 off the price on the Internet. For a small yard, I was deliberating looking for the smallest one I could find. I routinely go back and forth through a 4' gate, although I do have another bigger gate that I use for my trailers. With the deck housing, I doubt that even a 42" cut model would fit through that 4' gate.
   / Why are Zero-Turn Mowers so Expensive? #20
jcmseven said:
I have found the wide marging actually not to be the case in my experience.
John M
John, after I read the the above quoted sentence I can say that since I have owned a Z-turn, my mowing/trimming time has greatly decreased. I used to mow with my TC24DA and a Woods 60" RDM. With the tractor, it would take me nearly 4 hours. This time did not include time spent with the push-mower covering spots I could not get with the tractor. Since owning the Z-turn, I can have ALL of the mowing/trimming done completely in under 2 hours.
I will also say that I have some pretty decent slopes that when on the tractor in 4wd, made me nervous. Obviously the ground speed that the Z-turn has over the tractor is much higher, thus cutting mowing time in half. As far as the hills are concerned, I am honestly more comfortable on the Z-turn. It's all about technique.
However.....in four hours of running time on the tractor, I was lucky to burn less than a 1/2 tank (capacity a little over 5 gallons) of diesel. With the gasoline Z-turn (14 gallon cap., 2-7 gallons tanks), I'd say I could use nearly 5 gallons of gas. Obviously the diesel takes the winners circle there! The Cub-Cadet "Tank" that I bought was offered with a Cat diesel, but with a $14-15,000 price tag, I went for the Kohler 27hp instead.
I guess it's all in what and how much a person is doing. Since I am using the mower for myself only and the amount I mow, the commercial grade model made sense to me.
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2008 INTERNATIONAL PAYSTAR 5600I DAYCAB (A55745)
2008 INTERNATIONAL...
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A56129)
2019 FREIGHTLINER...
2021 Toyota Corolla LE Sedan (A53424)
2021 Toyota...
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
