Why aren't basements built in the south?
   / Why aren't basements built in the south? #41
Re: Why aren\'t basements built in the south?
Nice thread! I have been running around in 8 ft deep trenches in slop that theatens to go over the top of my rubber boots off and on for a few days now. We have completed the excavation for my walk out basement. It is only under the central portion of the house. Digging was not easy after getting down through the sandy soil and hitting pretty hard rock in several places. The basement excavation is about 8 1/2 feet deep. Water runs out of the walls where the sandy soil lies on the rock. Ground water is currently about 5 ft below surface and this is with 90 days or more since last precip of note. Since it is a walk out basement it can't be an indoor swimming pool.
I have trenched around the basement about 5-8 ft out from the basement excavation to intercept the ground water as it comes down the slope. I am putting 4 inch perforated roll pipe with a cloth sleeve over it in that trench. This drain pipe will have 4 in of gravel under it and 4 inches over it with the whole thing wrapped in geotextile. One end of the trench goes to a creek just up from a pond and the other goes into the pond. This intercepting trench will reduce the amount of water getting to the foundation of the basement and also protects the leach field site from ground water.
I am using rigid perforated pipe as perimeter drains for the basement foundation. One loop outside but adjacent to the foundation and the other loop just inside the foundation. I have trenched in 4 each 4 inch drain pipes from the southeast corner of the basement excacvation to the nearest pond. I plan to have the northwest corner of the basement the "high point" and the southeast corner (where the drains are) as the low point. The outer loop attaches to the two outer drain pipes and the inner loop to the two pipes in the center so no pipes cross over another. The intercepting trench "Y" into the trench with the 4 rigid pipes downslope of the south side (down hill side) of the basement.
The idea is to intercept the ground water as it flows down slope before it get s to the basement. Of course, some water will get to thte foundation, whether by sneaking past the intercepting trench somehow or by falling as rain between the intercepting trench and the basement wall. Anyway the dual perimeter drains inside and outside of the foundation wall should take care of that.
Why a basement in south central Oklahoma? This walkout basement will contain the mechanical spaces and its noises. It will provide a fairly secure (tornado resistant) guest bedroom, a second small kitchen, a bathroom convenient to the back yard, space for both a direct vent propane gas log fireplace AND a small wood stove AND plenty of space for at least an 8 ft if not tournament (9 ft) pool table. I am still debating the window situation for the guest bedroom. I will probably go with a pair of fairly small windows with internal safety shutters which will be out of sight behind the drapes. Probably 1/2 inch steel or as advised by competent authorities. The guest bedroom door is not visible from the window wall of the "Pool Room" so I haven't decided if it gets a FEMA approved saferoom door.
The master suite of this house will have foot thick steel reinforced concrete walls, will sit on a slab floor, and will have a cast concrete ceiling. I am still debating windows for the bedroom which has an adjoining sitting room (within the master suite) which has a window wall on the south side and a fireplace. The master bath, bedroom and walk in closets will be inside of the reinforced walls and have concrete ceilings.
My wife's digital camera started acting up and I am remiss in getting a new battery so am missing many photo ops. I think it is the batt as it works fresh off the charger but not a while later. If anyone is interested I could try to get some snaps of the building site. Looks like a war zone. Track hoe, back hoe, two 10 wheel dump trucks and a dozer (I returned the rented Bobcat with 500lb hammer chisel on front.) Huge dirt pile over 30 ft high. Building a dam for another pond and repairing another one with the excess dirt.
We brought the grade down a variable amount to get a slope from the walkout basement exit to one of the ponds. Near the pond we took out about 7 ft high penensula and made it about 3 ft above the water. There is a 6 ft drop from the basement excavation to the water surface in the pond. We will use about 3 ft of that as slope to the back yard and I will raise the water in the pond about 3 ft by repairing the spillway.
In theory everything is going to drain as all drains have redundant paths and it is downhill from the basement to the pond. There is a closer pond which we are not draining to because its water level is higher than the basement. It has a very nice thick dam and I am installing a 14 inch steel drain pipe (0.4 inches thick) and contouring the land where its overflow is so that even in a very significant rain event, the worst that should happen is some water may cross the lower portion of the back yard but in a wide and shallow situation that will not cause erosion nor harm the lawn. The dam I am building is upstream of this higher pond and that pond will moderate the creek flow to this pond. The new pond will also have a 14 inch overflow pipe and the dam will be significantly higher than the drain pipe for good surge storage.
By now you can probably tell we wanted a basement and a high liklihood of it NOT being an indoor water feature.
I like the idea of a walkout basement with a south facing window wall but if done properly a conventional basement can be bone dry, even with several window wells. Musty wet basements are avoidable, especially with the modern technology at hand. It is a shame that so many poor basements are built, it fosters the notion in the uninitiated that all basements are mildew farms.
I think I'll quit before I need chapter headings...
Patrick
   / Why aren't basements built in the south? #42
Ah OK so there are more windows on that side.
That looks more "normal" to me !!
Cheers
   / Why aren't basements built in the south? #43
Patrick,
Yes, please post pics. I prefer to look instead of read (I do plenty of that for school). Also, did you get your shelter info from FEMA or the web (or both, e.g., the FEMA web site). If from the web would you mind posting links. The wife and I live NE of OKC. We plan to buy more and build bigger after I graduate and have a couple years at a real job (read real income) under my belt.
I haven't done a search on TBN for shelters, but I thought since you've got the experience I'd inquire.
Clint.
   / Why aren't basements built in the south? #44
Neal, they do that small window thing around here too. I think it is the cold that causes them to do it that way. Here and there, especially in higher end homes you see lots of glass. I have huge windows across the whole back of my house and even a 5 foot skylight. Nothing substitutes for natural light or makes a room feel bigger than large windows that bring the outside in. My house in Phoenix had a glass wall across the back against the patio area and adjacent to the pool area. When it gets cold I just turn the propane up, the gas company likes me! Oh, they all told me that my skylight--glass would shatter in a hail storm. Well, I have had the roof replaced due to hail, skylight is still there. It is made from laminated glass, if it goes it is probably time to call the insurance company with some really bad news. It is kinda neat laying on the couch looking up at the hailstones as they whack into the skylight and bounce off. /w3tcompact/icons/shocked.gif
When I was in grad school I had this smarty pants prof from up Northeast some place, he told me in a weather discussion, a 500 level geoclimatology course that hailstones could not exist larger than about hardball size. I said well your wrong--my moma say they can be big as grapefruit. Well, my moma was right, the mother of hail storms hit two weeks latter shredding the dudes prized cloth top Jageware car in Brit racing green and all the other cars too, houses, boats, animals, you name it. I had a flock of ducks in the bayou across from me, after the storm I had a collie dog with a whelp on its head where she had tried to bring the ducks to their pin, I had a wife with a whelp on her head from picking up the dazed collie, I had a house with no roof, two destroyed cars--totalled!!!! and several dead ducks. The house had tongue and groove lumber under the shingles, it broke though the wood in several places and damaged the interior ceilings in the bedrooms. The prof moved. J
   / Why aren't basements built in the south? #45
Austin ---west of the fault line = limestone and $$$$$$ to dig in --- east of the fault line = black gumbo -- if you put a basement in it you'll end up with an indoor pool or a problem with getting the water to drain away from it at the very least. There is no need for basements - frost lines etc - so why build in problems that aren't needed? On the other hand it, slabs don't make sense to me on that clay either 'cause they move and crack ---- my house will be perimeter wall with a crawl space and piers -- that way I can fix any movement without a lot of expense.
   / Why aren't basements built in the south? #46
we built a house in central NC, yellow and red clay area, on a 10/1 slope. They dug out a pretty good size hole for a 2200sq/ft basement/crawl space and filled in a gulley with the extra soil. We had solid poured 10' walls and roughed in facilities in the basement slab. In the breakdown of the costs, the builder charged us $30/sf for the basement and $85/sf for the finished upstairs area.
So cost wise, I'd do it again in a hearbeat. Thus far, no cracks, no leaks, lots of spiders. My woodstove in the basement dries it out pretty good every year.
Eventually, we'll finished off this space into more living space, but for right now it's a great place to work on projects.
gary
   / Why aren't basements built in the south? #47
I just have to suggest you extend the rebar thru the windows in the master suite and you could rent it out as a Supermax prison. Just kidding/w3tcompact/icons/hmm.gif/w3tcompact/icons/wink.gif
   / Why aren't basements built in the south? #48
Clint, I have downloaded and read the FEMA info. I did not specifically follow their info when building my mom's saferoom. I may have built it a bit sturdier. I even reinforced the FEMA approved saferoom door and uses three deadbolts plus a regular latch set.
5/8 rebar on 8 inch centers vert and horiz in floor walls and ceiling. Floor and ceiling are about 14 inches thick with a double mat of rebar 5 1/2 inches apart in ceiling. Walls are 12 inch thick "knockout block with 100% grouting. I used 2ft by 2ft prebent rebar corners in 5/8 inch in horizontal plane to tie walls together at corners (8 inch centers). I also used the prebent corner rebar to tie the floor to the walls, also on 8 inch centers. Similarly I used the corner rebar to tie the ceiling to the walls. Each piece of rebar in the ceiling is tied to the wall by a rebar corner, both mats.
Heavy floor is partly for ballast. I cored (drilled) into the garage foundation and doweled from the safe room floor to the garage with rebar to anchor safe room to the garage foundation.
Yes, I saw "Twister." Yes, I personally viewed the wake of the F-5 in Moore.
For amenities I installed a 100 AH 12 V batt in the garage just outside the safe room and some 12VDC fluorescents for lights. Oh yeah, I formed up three each 4x6 inch ceiling vents for fresh air and mounted the FEMA safe room door an inch and a half higher off the floor than standard. Cool fresh air comes in under the door and warm stale air rises out the ceiling vents. I welded expanded metal to the bottom of the door as a debris strainer. I intend to place steel weldments over the ceiling vents even though it is unlikely that debris will be hurled vertically downward through them. They are near one wall, away from futon so no injury would be likely if something did come in.
I think I ended up with a steel box with some concrete on it. It looks to be a part of the garage and has the same vinyl siding and roofing as the house.
Regarding my new home and the master suite safe room. The walls are to be cast concrete one foot thick with rebar vert and horiz. Ceiling will be at least 8 inches thick but no more than a foot so the second floor's floor level will match part of house without safe room beneath. Floor is slab-on-grade. the door between the master bed room and sitting room is to be safe room door, skinned for eye appeal. The great room to master suite door will be a skinned safe room door also. With the right hinges those heavy doors move quite easily.
The master suite safe room may not be as safe as my mom's safe room(probably way over engineered) but... I think it will be good enough. Strength goes up as ceiling spans and wall lengths are reduced. If we actually experience a tornado I am confident the bedroom will likely hold up plenty long enough to walk a few steps into the walk in closet which will be even more secure.
I did get some snaps today. Pretty boring. I'll post one.
Patrick
   / Why aren't basements built in the south? #49
Here is the basement excavation with equipment in background and a couple ponds.
   / Why aren't basements built in the south? #50
Patrick,
Thanks for the info. Printed and filed for future reference.
Clint
2017 Ford F-350 Crew Cab 4x4 Pickup Truck (A53422)
2017 Ford F-350...
2005 International 4200 Texoma UC-301 Pier Drilling Truck (A52377)
2005 International...
2007 Ford F-550 Crew Cab 11FT Flatbed Truck (A51692)
2007 Ford F-550...
2007 Ford F-350 Stakebody Flatbed Truck (A51692)
2007 Ford F-350...
2020 Kinze 3505 High Speed 6/11 Planter (A53473)
2020 Kinze 3505...
CAT Skid Steer (A50322)
CAT Skid Steer...
