Why could someone not handle the heat?
   / Why could someone not handle the heat? #31
Thanks for the update... hopefully they can figure out what's going on.
   / Why could someone not handle the heat? #32
good update, glad he's going for medical consultation.
   / Why could someone not handle the heat? #33
My crew and I work in temps over 110 from now till Oct. All the things others have posted are possibilities of his heat problems. Age, salt, heart, liver, kidneys etc.etc. If he is drinking that will dehydrate you into the next day, if he's an alcoholic or just drunk every night. Coffee will also dehydrate you.
What I do that works best for me is to SUPER HYDRATE myself the night before a long hot day outside. The next day I start drinking water from the time I wake up and throughout the day. Water will taste like medicine as you force feed yourself water.
If I do this I'm fine, if I don't I'm useless in the heat.
Also drink pedialyte or a Sports drink . Never cokes, coffee, beer etc.
A trick that was taught to me by a giant Black Man when we both worked in paving roads. He always called me " Young Blood" . He taught me to run cold water on my wrists and it would bring my core temperature down. One of the best trick ever taught me. I wonder ever happened to Rufus?
   / Why could someone not handle the heat? #34
Keeping the sun off you head and neck is important too. If I really have to work in hot, hot weather I try to cover up my head and neck. If that sun is beating on your neck you are in trouble because the sun heats up your blood running through the neck. I will take a small towel, soak it in water, fold it up so that a bunch of it is on my head and under my hat with the rest of the towel covering my neck. The water evaporates and keeps me cooler. I learned this little trick in the South FLA summer while digging a trench near a pool. I was so over heated I kept going to the pool shower and wetting my self down every 15 minutes or so. Eventually I did the towel and hat trick and that really helped.
The wrist cool down works just what I do with covering the neck. There are products out there for wearing on your neck to keep you cool. I think you put them in the freezer/fridge before use and the wear them. My towel is cheaper though and won't break. :laughing::laughing::laughing:
Later,
Dan
   / Why could someone not handle the heat? #35
Interesting post. I work outdoors quite a bit and found that if I start when it's cool out and stay outside all day, I'm find, but if I come indoors and cool off, or get a late start and it's already hot outside, then the heat becomes an issue.
Eddie
   / Why could someone not handle the heat? #36
wear a T shirt and keep it wet as well as the hat on your head. Evaporating water cools.
   / Why could someone not handle the heat? #37
I have been told many times that a long sleeve shirt will keep you cooler than a tee shirt. Can't bring my self to keep a long sleeve on to find out, but it seems many/most guys on paving crews wear long sleeves.
   / Why could someone not handle the heat? #38
On the weekend the heat does not affect me much if I start out early in the morning and stay out the rest of the day. However during the week having to work in AC and car with AC it is difficult when I get home and its 90+*.
One thing I do is always wear a big straw type hat, wet towel, cooler with low sugar protein bars and apples. I always have plenty of water with me.
I have started carrying Propel water with me. It has some vitamins and minerals in it, not much but some. The Kiwi/strawberry really cools me down, actually better than water. The doctor recommended this to my wife when she was dehydrated instead of the sports drinks.
Propel Enhanced Water
   / Why could someone not handle the heat? #39
The asphalt is hot. Long sleeves protect from the direct heat. The fellows also may have extremely hot feet.:)
You'll notice the tradition dress in dessert countries covers almost the entire body with the clothing so arranged an upward draft for cooling is formed.:)
   / Why could someone not handle the heat? #40
Not to distract from the thread but I read an interesting article a few years ago about controlling core temperature (in an in-flight magazine of all places). It was some research done at a university where they looked at core temp levels and fatigue.
As your core temp starts to rise your body starts to fatigue you so that you do less work thereby lowering your temp again. What I got out of the article is that three areas of the body have blood that basically goes straight back to your core, the palms of the hands, the bottoms of the feet and the face. Makes tons of sense when you think about it; putting your feet up by the fire, rubbing hands together and holding them out to a fire/source of heat, turning your head towards the warm sun. All things you do instinctively to get warm. Same areas can work for cooling.
You can't do it suddenly like with ice or your blood vessels constrict, has to be a 'cooler' source that gradually brings your temp back down. These guys made a glove that puts a slight vacuum on the hand to draw in even more blood to cool it down. I am one that doesn't deal with the heat well and in places like on a plane where I am sometimes hot and uncomfortable I get real irritable. Now I know to just take my shoes off.... the floor is usually cool, especially once in flight. Works wonders.
2022 Ram 2500 (A55973)
ALLMAND NIGHT-LIGHT PRO 4 BULB LIGHT PLANT (A52706)
ALLMAND...
KUBOTA X1140 CREW RTV (A52706)
KUBOTA X1140 CREW...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
2024 ArmorLite Aluminum End Dump Trailer (A56438)
2024 ArmorLite...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
