Why does starter fluid cure my no start? What is the issue?
   / Why does starter fluid cure my no start? What is the issue? #31
Either the needle and seat leak in the carburetor leak, emptying the bowl, or the fuel pump is weak or leaking.
It won’t start because it isn’t getting fuel into the combustion chamber. Shooting ether gets the engine to fire and run at a high enough speed to reprise the carb.
The Brigs engine on my lawn tractor does the same thing if I let it sit for a long time. It will fire once, then become very difficult to start. If the battery is fully charged, it will retire after an extended cranking period.
If the battery is even slightly discharged, and the tractor has been sitting, a whiff of starting fluid gets it going.
Once started, it will restart with no issues.
I really need to make some time to rebuild the carb and vacuum check the fuel system for leaks.
   / Why does starter fluid cure my no start? What is the issue? #32
Forum Junkie, You don't give us a whole lot of information with which to help you. I assume that after you do get it started it runs fine? What color is the spark plug electrode? Black or tan or light colored? Black indicates too much fuel, tan is good, whitish means not enough fuel. Is it getting good spark? Does this engine have a choke? Does it work? (That reduces the engine's the air when starting to give the engine more fuel... sort of like using starter fluid)
From my experience, people make problems worse by guessing at the problem than approaching them systematically. Blind repairs often fix (or break trying to fix) things that aren't even the problem. If it runs fine after you start it, I am curious as to why would you think it is a fuel pump or vacuum problem?
   / Why does starter fluid cure my no start? What is the issue? #33
I put a 4PSI fuel pump on my engine.. no more waiting for the fuel to fill up the bowl!!.
   / Why does starter fluid cure my no start? What is the issue? #34
I would check that the choke plate is correctly returning to the closed position when the engine is off.
This would be my first suggestion also. Make sure cable hasn't slipped and choke is working as it should.
   / Why does starter fluid cure my no start? What is the issue? #35
It probably had a sheared flywheel key. Most likely from someone using starter fluid. :rolleyes: :laughing:
One backfire is enough to shear a key and ****** timing. That's all it takes to make an engine hard to start. It all begins with a bad plug, fuel or air problem. Starter fluid is NOT a fix. :laughing:
Unlikely. It was hard to start from Day 1 and I bought it new. To the best of my knowledge, it never backfired. The heavy flywheel of the chipper was probably the issue.
   / Why does starter fluid cure my no start? What is the issue? #36
If your fuel is over a month old, try to drain it and start with fresh purchased gas.
When you pull up on the choke knob before starting, can you tell if it's activating the choke lever on the engine?
   / Why does starter fluid cure my no start? What is the issue? #37
Propane Pickmeup system
   / Why does starter fluid cure my no start? What is the issue? #38
That's what I was planning on doing. Does one leave the tiny orfice on the tube or take it off? I mean. engines start with the orfice and nozzle in place, so I'm guessing leave it on to reduce flow.
   / Why does starter fluid cure my no start? What is the issue? #39
The orifice will reduce flow too much for an engine to run.
Better you should throttle up & back down with the valve.
It'd start better when cold running 'rich' than lean regardless of fuel.
btw, a leaking needle and seat will not drain the carb bowl, it would overflow and 'flood' the engine. Lacking a fuel shutoff it could overflow enough to fill the crankcase with gasoline.
   / Why does starter fluid cure my no start? What is the issue? #40
I agree with the old grind. Likely summer fuel. Try using a shot from a propane or butane torch (unlit). If that works, it's probably summer blend. Summer blend has less butane in it.
Ralph
Case 1083 20ft Corn Head (A56438)
Case 1083 20ft...
2014 International WorkStar 7300 4x4 Altec AA55E 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56438)
2019 Krause...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
2020 MACK PINNACLE (A58214)
2020 MACK PINNACLE...
