Why I Need More Than 1 Tractor
   / Why I Need More Than 1 Tractor #31
Perhaps something Amish here. Trying to figure it out. We have a lot of Amish and Mennonite around where we live now. We are the odd ones here and not them.
We're up in the Holmes County area a few times a year working with and learning from some of the Amish farmers in that area; they are a wealth of knowledge on doing things smart and simple.
   / Why I Need More Than 1 Tractor #32
Have you considered a PTO cart...
Draft horse, mule, and oxen power - Rural Heritage online
Liberty PTO Cart
So, you get to change the engine oil AND muck out stalls? KISS in reverse...
You're not saving much money over buying a tractor either.
   / Why I Need More Than 1 Tractor #34
You always need a second tractor to pull the first one out of the mud.
So what do you do when the second one gets stuck going after the first?? ;)
   / Why I Need More Than 1 Tractor #37
Back when all I had was 2wd tractors, If I had to go into an area where there was a risk of getting stuck, I would never use my largest tractor. That way I could always use the big one, held in reserve, to get the smaller one out. I have never got a 4wd stuck in 5 years since owning one. One time, when I lost traction on all 4 tires pulling a disc thru a mud-hole, I simply used the bucket to pull myself out. With 4wd, there is rarely a reason to remove the bucket, as the weight up front dont hurt you like it does on a 2wd, and you can always use it to pull or push your way out of the mud. I cant imagine a sitation that would cause me to get my 4wd with R1 tires stuck, but I have a healthy respect for the mud from many years of 2wd tractor operation.
   / Why I Need More Than 1 Tractor #38
Since I didn't have a second tractor to start with, when I got the 861 stuck twice, I just used the truck.
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
2018 CATERPILLAR 242D SKID STEER (A60429)
2018 CATERPILLAR...
2008 Ford Fusion SE Sedan (A59231)
2008 Ford Fusion...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
2015 DODGE DURANGO RT SUV (A59575)
2015 DODGE DURANGO...
2007 FREIGHTLINER M2 26FT CDL REQUIRED BOX TRUCK (A59575)
2007 FREIGHTLINER...
