Why idle before shut off?
   / Why idle before shut off? #91
ok i see your point and can agree on that because the oil will be in the rings groves created during the honing process not the piston rings but in the cylinder its self but it cant be very much oil to change the level like others have stated thats what i was getting at because if thats the cause it would smoke and would be a weak motor
Yes sir, you are correct, it's not enough oil to cause a drop in the pan, but oil has to be there or the rings would heat up and sieze.
   / Why idle before shut off? #92
and in some peoples case just cause they see it dont mean its there i have road in a truck with a mad like that now talk about scarry 8 hour ride
but it shouldn't use enough oil to drop the oil level unless u dont change it when u need to and let the oil break down and thin out
   / Why idle before shut off? #93
and i have seen rings sieze to cylinder walls and break but figured that was because somebody over heated the engine which could be the case on some occastions. but u make all the sense in the world with that because everybody thinks the water is for cooling and oil is for lube but oil is also used for cooling down
   / Why idle before shut off? #94
Yes sir, and thank you.........oil is used for lubrication and cooling.
Most people don't understand the concept, but that is the case.
That is why they put 'oil coolers' on vehicles that are going to be doing a lot of towing or working in the fields.:)
   / Why idle before shut off? #95
i just have one more dump question if a farmall cub does not have a water pump, but is water cooled. would that be a exception to the rule or not? because it does have a thermostat does it hurt the motor to just shut it down before idling down.
i am just curious how that motor cools the water is all i have never worked on one of the motors in a farmall and is curious to know
   / Why idle before shut off? #96
maybe people that was saying it would drop the pan level will read the last few post, so they will understand the concept of the internals of a engine and how the work
   / Why idle before shut off? #97
Do not think that the temperature is a constant 3,000 deg. from the center to the cylinder wall. The cylinder walls will be cool enough to keep the oil from burning off if the engine is not over stressed. Once the oil is gone the piston rings will shatter.
   / Why idle before shut off? #99
I personally have never worked on a cub, so I can't answer the question.
But I am looking to possibly buy one...........and after looking over the water circulation process, I'll be sure to post my findings here.
But since you told me about the 'no water pump'........I may have to rethink my ideas.
   / Why idle before shut off? #100
That is a great question! :anyone:
I would expect that convection circulation is in effect and the running state of the engine would be irrelevant other than to provide an oil bath to certain parts until they cooled sufficiently. I don't know if the engine temperatures get hot enough for this aspect of cooling or metalurgy to be critical though.
Towable Centrifugal Water Pump (A59228)
Towable...
2018 Freightliner M2 106 Cab and Chassis Truck (A59230)
2018 Freightliner...
Kubota LA525 Front Loader Tractor Arm Attachment (A59228)
Kubota LA525 Front...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
HYDRAULIC WINCH RACK (A58214)
HYDRAULIC WINCH...
2010 Toyota Highlander SUV (A59231)
2010 Toyota...
