Why not use a finish mower
   / Why not use a finish mower
cartod said:
Adjusting the top link also will help eliminate windrows.
What adjustment do you recommend? I set the mower with the rear an inch or two higher than front. Once cut height is set on 3pt I put tail wheel on ground then loosen the top link for float. If I tighten top link I lose the float.
   / Why not use a finish mower #42
If you set it up level instead of the tailwheel high, it will give less windrows, but require more power and/or going slower to give a clean cut.
And I dont recommend it that often because they are high maintenance and slower and require way more power, but you should look into a flail mower vs the RFM.
Flails are slower than a rotary cutter, probabally about as slow as a finish mower in similar conditions.
   / Why not use a finish mower #43
I starting using a finish mower for my hayfield and it turned out better and better every year so I made it a runway.
   / Why not use a finish mower #44
Not the best photo, but a shot of our old place taken of the turkey at about 100 yards away. from the house. But you get the idea of what it looked like after a few years of finish mowing of just a rough field.
James K0UA
   / Why not use a finish mower #45
I've got a KK rear discharge too and I love it so much better than a side discharge.
   / Why not use a finish mower #46
Just mowed about 4 acres with a John Deere 261 side discharge mower and worked really well and the field was damp and about 3 feet tall in spots. My tractor is a 3005 JD and it has plenty of power for the 5 foot mower i just bought. Newbie by the way, first mower and tractor. Besides you cant mow in reverse on a rear discharge, made my decision on a side discharge because of that fact.
   / Why not use a finish mower #47
I do it all the time with my rear discharge. No problem.
I have a 6' side discharge rear finish mower and a 7' rear discharge rear finish mower.
Personally I prefer the rear discharge.
   / Why not use a finish mower #48
I had a 261 mower. Sold it to my brother because I have a ZTR now. It was a good mower and would handle thick stuff on occasion, but I wouldnt make a habbit of it. Being belt driven, small blades, and small gearbox, they are not meant for that kind of abuse for long. It you plan on mowing 3 feet tall stuff often, you better consider a rotary cutter IMO.
   / Why not use a finish mower #49
Being lazy?:)
Most of my mowing could be handled with a finish mower just fine and with marking some of the hill side and unlevel places.
I keep about 3 miles or road shoulders clipped that a finish mower would be great for but with the 7' rotor cutter I do not have to get off and move dead limbs and other stuff that can be found on the side of the road.
Light blades and belts is not something I have to think about with the rotor cutter. When do run up on a 3" tree I just keep going if I do not want it.
A wheel on each corner would be nice but they really need to be kept out of the dirt where as the bush hog actually will level old ruts, etc. :laughing:
   / Why not use a finish mower #50
Just bought it so the grass was tall as He@$ but its not considered a small gear box for its size, really small ones i saw where on new ones in the same price range, The gears look Huge compared to the landpride 5 footer i looked at. But your right i am sure its not meant to cut tall grass, but now its knocked down i can maintain it. Its difficult to find info on the 261 JD but older folks have told me there pretty tough, so well see.
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2015 Ford Fusion Sedan (A55853)
2015 Ford Fusion...
John Deere 1025R (A53317)
John Deere 1025R...
2012 BMW 328i Coupe (A55853)
2012 BMW 328i...
2017 Kenworth T400 T/A Aquatech B-15 Combination Sewer Jetter Vacuum Truck (A55852)
2017 Kenworth T400...
UNUSED FUTURE HYD MINI HEDGE TRIMMER (A57193)
UNUSED FUTURE HYD...
