Why should I not buy a Cub Cadet EX vs a JD or Kubota
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #1
offroadr
Central IL
JD 3320
I tested a new EX3200 this week and I really liked it, especially for 15,999 with a FEL. With a 3320 JD going for about 20k with the 300cx, I am having a hard time justifying the extra $$. A L3400 with a FEL will run around 18K.
The Cub Yanmar seems like a decent machine (basically an upgraded JD790). The one thing I see is possibly reduced resale value since its not a popular color.
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #2
I looked at a Yanmar Cub recently (not in the market- I was buying an implement); seems like a nice machine. Are JDs still Yanmars or did they change manufactures when Cub changed to Yanmar?
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #3
All JD 3XXX's have the Yanmars. The JD 4XXX's have JD engines.
Note the differences between JD and Cub Cadet below.
3-point lift:
JD 3XXX specs:
Lift Capacity (24-in. behind link arms), 2200 lb.
Lift Capacity @ lift link ends, 2530 lb.
Cub Cadet EX3200 specs:
Lift Capacity (24-in. behind link arms), 1100 lb.
Lift Capacity @ lift link ends, ? lb. (not listed)
Loader:
JD 300CX specs:
Lift Capacity at full height
(measured at pivot), 1492 lb.
(measured at 500 mm ahead of pivot), 1047 lb.
Cub Cadet CL300 specs:
(measured at pivot), 900 lb.
(measured at 500 mm ahead of pivot), 770 lb.
Excellent summary there! I think I will be happy I went with the 3320
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #5
Cub cadet seems to weave in and out of the CUT market. I would be worried about parts and service down the line.
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #6
Cub thinks CUT is the first part of their tractor sales strategy - CUT and RUN.
They have dabbled and dropped tractor for a while. poor support.
You'd do better elsewhere.
jb
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #7
Don't underestimate how important parts support is. The Cub may be an upgraded 790 but it sure ain't a 790 as far as parts availability and support goes - now and 10 years down the road.
Today I dropped by the neighbourhood Kubota dealer to buy a teeny tiny 'breather plug' for my front axle. It is a .5 or less cm square plug for the front axle that you are supposed to remove before pumping grease in. I overtighted it the last time around and in attempting to remove it for greasing this time, rounded the bugger off.
Figured they MUST have to order this in. My L3400 Kubota is a popular model but how many guys around here are rounding off their teeny tiny breather plug?
Caught the parts guy just as they had closed up shop for the day. He opened things up for me, found the part on the computer and had it in stock!
It's not only important to get a brand that will have parts support for time to come, but also IMHO to get a model within that brand that is popular enough so that stuff will be on the shelves for time to come.
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #8
jb
I agree. If they are anything like the LT series lawn tractors, turn and walk away.
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #9
I would be looking at the Kioti CK30.
Thanks for the replies. I went with a JD3320. Support and resale was a reason to spend a little more on the JD.
Thanks again this is a great website!!
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #11
Can't go wrong with a JD! You'll like it a bunch.
jb
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #12
I looked at the cub too.
The price difference between it and the Kubota L3400 was $400.
A couple of things that I saw--
Cub was same price regardless of tire type, Foldable or rigid ROP.
Kubota Tires are different price, and same for ROP.
The cub was $16K and the Kubota was $16400
(Kubota had a foldable ROP and AG tires, All others were more $)
In the end I liked the way the kubota HST worked, and specs seems better too...
(measured at pivot), 1503 lb.
(measured at 500 mm ahead of pivot), 1186 lb.
Lift Capacity (24-in. behind link arms), 1435 lb.
Lift Capacity @ lift link ends, 1998 lb.
anyway-- Kubota lists for the $18K figure, but never pay list- find another dealer! I did and dropped $1600.
Later,
Jim
   / Why should I not buy a Cub Cadet EX vs a JD or Kubota #13
Have to say that I was pretty surprised when I saw the 3 pt lift difference between the L3400 and the Cub. It's pretty significant. Don't think tht the Cub would be able to lift the round bales I've been lifting with my L3400.
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
Year: 2014 Make: Acura Model: MDX Vehicle Type: Multipurpose Vehicle (MPV) Mileage: 183,948 Plate: (A59231)
Year: 2014 Make...
2021 Ford F-150 XL (A53317)
2021 Ford F-150 XL...
FUEL CELL TOOLBOX COMBO (A58214)
FUEL CELL TOOLBOX...
2013 Chevrolet Van (A55973)
2013 Chevrolet Van...
2011 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2011 VOLVO A40F...
