why shouldn't I do this to the 3PTH? geometry?
   / why shouldn't I do this to the 3PTH? geometry? #1
oldboyscout
ne PA
Kubota B2620
I just added carter&sons quick attach brackets to my lift arms. They are mounted on top, not out behind. I realized however that effectively makes the pins close enough to the top link that it's like using the lower mount point for the top link -- and my manual says to avoid that.
Any ideas why?
   / why shouldn't I do this to the 3PTH? geometry? #2
A picture would help but by your description I'd hazard that it would make the attachments place their weight at an unacceptable angle that your tractor wasn't designed for.
   / why shouldn't I do this to the 3PTH? geometry? #3
Any ideas why?
Huh?
If I understand you:
1) You didn't change the mounting point geometry of the attachment(s), so the height between the aft ends pivots of the drag links and the top link when it's hitched will be the same.
2) You didn't change the forward position of the drag links and the top link attachment points to the tractor.
So ... I think your implement may raise a few inches higher, and will not drop as far by the same amount. But the 4 bar linkage formed by the pivot points is about the same as before. If your range of motion is acceptable, I wouldn't sweat it. If not, then you may be able to shorten the length of the lifting links by repinning in different holes or turning the turnbuckles to get a more favorable range of motion.
A picture of your 3pt with QA brackets installed would really help.
yes it does lift higher, and I think a steeper angle , but I'm not sure. I think the arms go plenty low for everything I deal with (for now?)
   / why shouldn't I do this to the 3PTH? geometry? #5
What B/G said ... :thumbsup:
larry
no I didn't move the top link to the lower mounting point, but moving the eyes of the lift arms up looks like I essentially did the same thing. i.e. the distance between the top link and lift arms is shorter now.
I don't understand why using the lower top link mount is discouraged.
   / why shouldn't I do this to the 3PTH? geometry? #7
Moving from top to bottom of the top link is for the Draft control, This changes from tractor to tractor, if you tractor doesn't have Draft then it doesn't matter. use what ever works.
If it does have Draft, the hole closest to the Draft sensor will need more pressure on it to react, compared to the one furthest away. However this does change with different tractors, Don't think I've seen to many that are the same.
   / why shouldn't I do this to the 3PTH? geometry? #8
Huh?
The height's the same on the implement, but the geometry *on the tractor* is different. The top link will be at a steeper angle when the drafts arms are in the same height, or the draft arms will be lower when the top link is at the same angle.
Be careful with PTO shaft lengths. The same draft arm height will now make a sharper PTO angle and your max PTO angle has increased. Don't poke a hole in the tranny...
Your 2nd biggest change is that you may not be able to get implements as far into the ground when you drop them completely.
   / why shouldn't I do this to the 3PTH? geometry? #9
agree with Andrew it has to do with the third arm either with draft or the strength of the hitch point. It looks to be on a Kubota and mine that has draft reads about like you are talking as yours does.
You may have looked at and done this but you probably have two holes in the arms for the lift linkage and is you use the holes nearest the top of the arms get the lift point where it was.
BTW, interesting set up you added there.
   / why shouldn't I do this to the 3PTH? geometry? #10
Only problem I see is the possibility of the driveshaft hitting the front edge of the mower when fully raised. That could do serious damage to the tractor pto internals.
tim
   / why shouldn't I do this to the 3PTH? geometry? #11
One additional concern with quick hitch (eliminating the ball mechanism) doesn't allow you to offset (left or right) the implement. Not sure if that is true, but appears to me that way. You can probably still use original lift point (with the ball joint) if you do want to offset implement, assuming the new quick hitch is not in the way.
   / why shouldn't I do this to the 3PTH? geometry? #12
From your photo it appears you have welded the Carter hitch to your lift arms instead of using the pin holes in the quick hitch and pins through the lift arm balls. Doing this you have eliminated any slight alignment play between impliment and 3 pt arms, thus making a very rigid engagement, which will put an increased strain on 3 pt. hitch arms and the implement pins. Personally I don't think I would have welded the Carter hitches on the lift arms as I like the little play that is utilized by the lift arm balls.
hadn't thought about the PTO shaft. I'll check carefully.
I wasn't aware the the pin on QA had any play since there is a tube that slips over the lift arm and pins through the ball.
There does seem to be a little play where the implement pins sit in the QA.
The only thing I need play for I think is my box blade, and as was mentioned it looks like I can still attach that the normal way if necessary.
<You may have looked at and done this but you probably have two holes in the arms for the lift linkage and is you use the holes nearest the top of the arms get the lift point where it was. >
yes the lift linkage has 2 adjustments but it's normally on the lower one. If I use the upper will it get worse?
another question then, what are those adjustments for?
   / why shouldn't I do this to the 3PTH? geometry? #15
Its possible that thats how its done.(welded) They offer either weld on or the ones with the bracket..I agree with the loss of ''play'' but on the plus side you don't loose the length..
yes i wanted ones that didn't extend the length the arms because I don't have a lot of lift capacity to begin with and I didn't want to lose any of it.
the weld-on vs the pin on was a toss up but I thought the weld on would be cleaner with fewer clearance issues.
   / why shouldn't I do this to the 3PTH? geometry? #17
Just noticed the "folding entrenching tool" in your sig ? ! ?
Do you mean by that a backhoe, or one of those little green folding shovels I always lashed to my pack when I was a 'scout? Do they still let them use those, or have they been litigated out of the quartermaster's inventory?
   / why shouldn't I do this to the 3PTH? geometry? #18
If this was a question from my post your manual will cover this. But one set of holes will give you less lift but more lift capacity. That I think is the rear holes holes. Best I can say it lift and measure and then switch and measure for difference.
   / why shouldn't I do this to the 3PTH? geometry? #19
On the lift arms imagine a line from your new "eyes" to the ball mounting point on the tractor. This is your new lift arm. Lengthening your lift links to bring the new eyes/new arms to their original position will cause virtually identical characteristics to the original. Forces consolidated in the composite lift arm/QA will be different but not felt much by tractor hydraulics owing to the small change in angle. The sweet/ strong spot in your lift range will change a little. Loss of the outer ball articulation will cause some binding if you tilt implement. Moving your top link point will be the same as if the lower links are stock. --Lower link point reduces lift capacity some but kicks the implement tail up quickly as you raise.
larry
Baby Grand, yep the folding army shovel. Closest thing the Scouts use now is a little garden trowel to dig cat holes for "personal sanitation"!
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
2015 Ford F-250 Crew Cab Pickup Truck (A59230)
2015 Ford F-250...
Kubota L4701 (A53317)
2018 Ford F-350 (A55973)
2018 Ford F-350...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
2019 WABASH DVLSHPC 53FT DRY VAN TRAILER (A59905)
2019 WABASH...
