why tym tractors loader lift rateings so much better than jd?
   / why tym tractors loader lift rateings so much better than jd? #11
Do some dedicated exploring! Did you know that some manufacturers loaders lift more then the front axle of the tractor is rated to carry!!!
SOME? I bet MOST will lift more than the front axle is rated for.
SR
   / why tym tractors loader lift rateings so much better than jd? #12
looking at a t234 tym tractor, its 25 hp and the fel is rated at 1380lbs lift at the pin,with over 2000lbs breakout force,, compareing it to many john deere models, it beats their loader rateings ,on the green tractors on models with over 35 hp,, im baffled
Ah shuck, moonmonky - you've triggered it now.....
You and lots of others, too. Best to just take loader specs with a grain of salt. Your common sense will tell you that in real world use, most loaders are going to perform pretty much the same.
There aren't any accepted standards for measuring loader performance - and it is rare for anyone to test it for themselves - so the only restraints on the advertising department would be self imposed.....
I don't know about your perceptions, but for me the next meek and conservative advertising department I see will be the first one ever.
And nobody even bothers to mention the important things about loader lift: Things like just how much counterweight is required?
How is the loader mounted? Does it have a full length frame - That's huge.
Along with mounting is the distrance from tractor nose to bucket edge. Is the loader a little too long or too close to the tractor?
Does it have optional auto-leveling?
Does it have hydraulic "bounce compensation" for driving with a load in the bucket. Sometimes called Comfort Ride?
How is the side stability at at full lift?
How does the loader visibility compare to the competition?
How delicate is the loader control at very low flows? < --- BTW, that's hugely important & rarely discussed. Really good loader valves seem to cost a LOT more than cheap ones.
Here's another thing never discussed: How does the tractor behave when turning sharply with a load in the bucket? How stable is it? Does it tear up the ground in 4wd?
Can you lean in the seat enough to get an idea of what the edge of the bucket is doing?
How instinctive is it to keep the bucket level on the ground?
What about changing buckets? Is it quick & easy to do?
There's a lot more to loaders than the advertising department's lift spec.
rScotty
   / why tym tractors loader lift rateings so much better than jd? #13
looking at a t234 tym tractor, its 25 hp and the fel is rated at 1380lbs lift at the pin,with over 2000lbs breakout force,, compareing it to many john deere models, it beats their loader rateings ,on the green tractors on models with over 35 hp,, im baffled . Im looking at used jd models mostly, because they cost alot more than the tym. Im looking for a tractor that is light enough not to crush sprinkler lines and rut residential lawns (badly), but still be able to pull a 5' box blade,and dig out my ditch line. I have a 1963 ford 4000 now,its to big and heavy for my custemers yards.
If you look at the TYM 234/264 its front axle is 3 times the size of a 3032/3038E. The 3032/3038E is a very low spec tractor with a front axle the diameter of my wrist and with a very light rear end. It only lifts approx. 1180lbs and at only about 86". Go to the "R" series and then you will see a different story but also a much higher price. TYM also manufacturers their own loaders and matched to the tractor they are mounted to.
   / why tym tractors loader lift rateings so much better than jd? #14
TYM specifications and pricing is very attractive. My main concern is parts availability.
   / why tym tractors loader lift rateings so much better than jd? #15
Kind of what I am looking at as well, as they out spec pretty much everything, but dealers and parts aren't as available, But when you are comparing prices TYM is 30% cheaper or sometimes more, for by all accounts as good as a tractor, it might be to good to pass up. I mean for a loader front blower and cab with heat and ac I get a 39hp or 47 hp for depending on how I finance for 30 -34k. In comparison the kubota 2650 is 30k, and John deere 3033 was like 38k, dont think I can justify that.
   / why tym tractors loader lift rateings so much better than jd? #16
I recently found the same thing when I was shopping for a tractor with a higher loader lift capacity. I found most of the information I was looking for on different tractors was through youtube videos. I was able to see tractors in real world use.
   / why tym tractors loader lift rateings so much better than jd? #17
Nards, your question is a good one, and we see it a lot on TBN. But let me ask it back - why do you think some brands are more expensive than others?
I'd like to believe they are just as good... who wouldn't? Just judging from the questions raised on the TYM forum here on TractorByNet, I don't see how you can say "by all accounts as good as" JD or Kubota. Maybe by some accounts by certainly not by all. When I look at the TYM formum there seem to be lots of questions about where to get parts and even where to find something as simple as parts diagrams. I don't honestly know which one bothers me - needing parts or not being able to get them.
What "good as" accounts are you looking at? I don't see them.
BTW, the messages I'm looking at are at:
https://www.tractorbynet.com/forums/tym-tractors/
rScotty
   / why tym tractors loader lift rateings so much better than jd? #18
I found that our JD 6200 has the reliefs set very conservatively. Quite annoying at times, when you drive into a pile and it won't lift without backing up a bit. But broken axles and stuff is annoying too.
   / why tym tractors loader lift rateings so much better than jd? #19
Besides TYM building tractors under their own lablel they also build tractors for Mahindra and Rural King as well. Many of the base tractors across the three brands are identical. The differences are engines and what each brand includes as standard equipment. They also have different lift capacities.
Example, a TYM T554 is the same as an RK55 and a Mahindra 2555 or 2655. They build A LOT of tractors so while getting the parts may take longer depending on distribution channels, the parts should BE available.
   / why tym tractors loader lift rateings so much better than jd? #20
rScotty
All accounts as in use and quality. I'm not sold on TYM yet to be up front, by I also understand that TYM has been making parts for orange and green and whole tractors for other names for decades. Why things cost more, well sometimes you get what you pay for, sometimes its brand recognition. I mean you pay 120 bucks for a pair nikes that cost 10 bucks to make, are they better than the $70 Reeboks, doubtful, but Nike has spent billions on their name and keep doing so, so they want a return and then some. So while somethings are quality and your paying for that, on a certain level you are also paying for a name.
Im still in the air while TYM is a thought but orange and green are not, frankly for me there is a better use of dollars for me and that fact that while under warranty its not my problem anyways.
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2003 Atlas Copco 75kW ABB Rotterdam 220psi Air Compressor (A52377)
2003 Atlas Copco...
Toro GreensMaster 1600 Walk-Behind Reel Mower (A53421)
Toro GreensMaster...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
Peterbilt Tandem Axle Road Tractor (A47477)
Peterbilt Tandem...
Ingersoll Rand Air Compressor (A52377)
Ingersoll Rand Air...
