Vanadium Steel
Henry Ford searched the world for the best materials he could find at the cheapest cost.
During a car race in Florida , he examined the wreckage of a French car and noticed that many of its parts were made of a metal that was lighter but stronger than what was being used in American cars. No one in the U.S. knew how to make this French steel—a vanadium alloy. As part of the preproduction process for the Model T, Ford imported an expert who helped him build a steel mill. As a result, the only cars in the world to utilize vanadium steel in the next five years would be French luxury cars and the Model T.
Vanadium is very corrosion resistant...
Also...
In 1905 Henry was at a race meeting, watching Malcomson's beloved Model K, the company's top-of-the-range six-cylinder heavyweight, when there was a smashup involving a French racer. Henry had been noticing for some time how certain components of European cars seemed to be much lighter and stronger than their American equivalents, and now, examining the wreckage of the French car, he picked up a little valve strip stem which was exceptionally light and tough.
"That is the kind of material we ought to have in our cars," he said, and he initiated an inquiry into precisely what sort of steel the valve strip stem was made of. It turned out to be an alloy of vanadium, which no American foundry then knew how to incorporate into steel. Making vanadium alloy required a furnace heat of 3,000 degrees Fahrenheit, and ordinary furnaces could not get above 2,700.
Henry found a small steel company in Canton, Ohio, to experiment with the process:
I offered to guarantee them against loss if they would run a heat for us. They agreed. The first heat was a failure. Very little vanadium remained in the steel. I had them try again, and the second time the steel came through. Until then we had been forced to be satisfied with steel running between 60,00 and 70,000 pounds tensile strength. With vanadium the strength went up to 170,000 pounds.
In March 1907, Ford took delivery of what the company claimed to be the first shipment of vanadium steel made in America. Produced in Canton exclusively for Ford cars, it had ten times the tensile strength of metal that the Carnegie Steel Company was currently turning out for armour-plate experiments.
"Vanadium steel resists shock," reported the Detroit Journal,"---either on blow or a series of lighter ones, or minute vibrations. . . to a greater extent than any other metal."
