Why you should change your oil
   / Why you should change your oil
Chris, don't you feel a little bit responsible here?
With all your knowledge and all, didn't you explain to your
brother in law the consequences of oil neglect?
I had no idea. Its a beautiful truck with a lift, 35" MT tires, and super clean. I bet he has $4000 worth of extas but was too cheap or lazy to change the oil.
Looking at it you would never know its not taken care of. Like mentioned above, this is the risk of buying a used vehicle.
Chris
   / Why you should change your oil #23
Buying used is maybe fine if you know the person selling and know he is up on maintenance, and know he wouldn't sell something like that for conscience sake. But people like that don't come around very often. That is probably the main reason I won't buy used.
I had a friend in the 1980s who had a car with 120,000 miles on it and we were talking maintenance. He was bragging on how reliable his car was and that he didn't ever have to grease the tie rods and the stuff in the front end and he hardly ever had to change the oil. I thought to myself I better not buy a car from him, but there are probably a lot of people like that.
   / Why you should change your oil #24
About how much oil was in the crankcase whan you drained it?
It holds 7qts and I got 6 out of it and another 1/2 qt in the filter. It had not used or lost any oil and I am fairly certain he did not check it because it took some effort to get the dipstick out. It was corroded in place.
Chris
   / Why you should change your oil #26
dodge man;3119990[COLOR="#40E0D0" said:
]I'll give the opinion that one late oil change in that number of miles isn't the cause of all the metal[/COLOR]. Its probably more the long term neglect that caused the problem. I had a co-worker that had a jeep and we had to push him in the parking lot one day. It turned out it he had bought it used, ran the thing for over 3 years and 40,000 miles and hadn't change the oil. That in itself was bad, but he also wasn't checking it so he ran it dry. This guy had a 4 year engineering degree, but no common sense. Of course the engine was toast. Some people just don't keep track of that kind of stuff and it has long term affects.
I agree with dave 18000 on an oil change wouldnt cause all that metal, some makes advise 12000 between changes.
   / Why you should change your oil #27
With synthetic, yes. With dino oil, 7-8k miles is pushing it in many cases.
I know someone who offers a 100k mile warranty on his rebuilt Diesel engines as long as you do 25k (yes, 25,000) mile oil changes with Mobil1.
Personally, I change the oil (Mobil1 Synthetic 5-W30) every ~10k miles when I put the snow tires on in Nov.
Aaron Z
   / Why you should change your oil #28
Aaron Z
I use the same oil and change at 7500 used to change at 5000
   / Why you should change your oil #29
With the right set of circumstances?, 18,000 miles could compute to well over two years, of abusive driving, winters, hot summers, traffic, over towing, heat gauge pegged, etc, etc. Just saying 18,000 without knowing the time and potential abuse meted out over that time is tough to make big claims about what's what here. Having done "maintenance" on folk's abused and neglected stuff over the years, just about your worst nightmare is entirely within the realm of possibility. For all Chris knows, it went 40,000 nasty miles before that last one, 18K ago, at the cheapo Quick Lube place and who knows what oil they even put in that thing? Was it to spec for that engine?
Far too many variables, but there's one known fact. The oil that came out crap. That's for certain. You'll find that filter was crapped out when you cut it open, Chris. For sure.
   / Why you should change your oil #30
Hard to tell how many miles he put on the previous oil change. Who know when he was going to change this time even.
MARATHON 20KW GENERATOR (A58216)
MARATHON 20KW...
Brown Metal Roof Panels (A55758)
Brown Metal Roof...
2354 (A58376)
2354 (A58376)
Tomahawk 42" Skid Steer Pallet Fork Attachment, Asset# 72 (A59076)
Tomahawk 42" Skid...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
Giyi Mini 39" 4-N-1 Bucket (A57149)
Giyi Mini 39"...
