WHY ???????????????
   / WHY ??????????????? #21
The hitch geometry is different also. The higher category hitches are made for higher hitch heights along with wider lateral and vertical spacing between the points. Bigger loads need bigger pins.
It was an excellent evolution. Implements were categorized by the loads they impose on the tractor and hitches were designed accordingly. If an implement is cat1, it will fit your cat1 tractor and not be too heavy for your CUT to pick it up.
   / WHY ??????????????? #22
Then to complicate the issue, there's the implements for SCUTs like mine. Cat 1 pins on cat 0 spacing. :)
Ian
2013 Haulotte 4527A (A57148)
2013 Haulotte...
Unused 2025 CFG Industrial MX12RX Mini Excavator (A59228)
Unused 2025 CFG...
INTERNATIONAL DUMP TRUCK (A52707)
INTERNATIONAL DUMP...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Mini Metal Goat Statue (A55853)
Mini Metal Goat...
2006 Mac Truck CXN613 (A56436)
2006 Mac Truck...
