Wide tires & rims...Jubilee?
   / Wide tires & rims...Jubilee? #11
Wish i could find prices like that. Here.. a 16.9x24 turf tire runs about 450$ with tube, installed. ( 400 for the tire I guess.. ).
Soundguy
Ya know, these are tubeless tires, should I be using a tube
also & if so why.
Keep in mind this tractor will see very little work, maybe
cut grass every once in awhile 6ft mower.
Hmm, maybe a tube to hold better air pressure?
Thanks again!
Gene
   / Wide tires & rims...Jubilee? #13
Tubes are good for a couple reasons... to hold air in a less-than-perfect bead ( rust/corosion.. etc. ), and for when filling tires with liquid ballast. the most popular ballast was CACL. nice and heavy.. and won't freeze.. it had a tendency to eat rims.. tubes staved that off quite a bit. Also.. on a conventional tubless tire.. if you get a sidewall hole.. your tire may be shot. If it is tubed.. you can slap a patch or boot in there to keep the casing from pinching the tube, and you are good to go. Using a tube.. you can use 110% of the 'good' out of a tire. I've seen a farmer take a tire that had a 6" long split from the tread half way down the side wall.. he sewed it up with BAILING wire and them put in a big farm patch on the inside and tubed it. It ran for years that way from what I heard. Even better. I've heard of a guy that sewed a 'patch' form another tire onto his tire when a chunk actually came out of the tire... gotta love farmer resourcefullness!
If they are tubless, run em.. if they have problems.. boot and tube them.
Soundguy
   / Wide tires & rims...Jubilee? #14
I had a brand new 12.4 X 28 for my Ford 650, was cutting grass for the neighbor. I ran over a T-post that was 8" out of the ground. Thanks for marking it /forums/images/graemlins/mad.gif It cut about a 6" gash up the sidewall of the tire. I cut up an old sidewall of an auto tire, and made a boot for the inside. I succured it with 1/4 X 20 carriage bolts, with body washers and nylocks. Been working fine for about 9 years now. I just couldn't see junking that new tire, it was only about tow months old at the time. Gary.
2019 HINO 195 16 FT BOX TRUCK WITH LIFT GATE (A53426)
2019 HINO 195 16...
(5) GOLF CART CANOPIES (A51248)
(5) GOLF CART...
2018 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2018 John Deere...
4 Drums of Paraflex (A51573)
4 Drums of...
49" X 74" EXPANDED METAL RAMP GATE (A51247)
49" X 74" EXPANDED...
2019 KENWORTH T680 TANDEM AXLE SLEEPER (A53426)
2019 KENWORTH T680...
