Will 6-12 tyres fit on 5-12 front rims ok?
   / Will 6-12 tyres fit on 5-12 front rims ok? #21
I'm not sure about tractor tires but I do know car tire manufactures are allowed plus/minus 5% difference from nominal size.
   / Will 6-12 tyres fit on 5-12 front rims ok? #22
Along the same Lines. Does anyone know if there's a difference between a 6.00-12 and a 6-12 tire?
   / Will 6-12 tyres fit on 5-12 front rims ok? #24
Here's a comparison between the old and new tyres, the Bridgestones are 5.5" wide across the lugs, new ones 4". Unfortunately the old Bridgestones have splits between the lugs that go right through in some places, they're probably 30 years old though.
[/QUO
I have been looking for replacement 5-12 tires for a long time now . I have Bridgestone originals and the lugs are deep & aggressive unlike most of the shallow replacments available which are only 1/2" deep . I just found a source which have 3/4" deep lugs that are made in China . I plan on ordering them in the morning after I confirm the size .
Mike
   / Will 6-12 tyres fit on 5-12 front rims ok? #25
@kc5sii
Hi,
600x12 is about 2" taller than a 6x12.
Use a 7x12 instead...same height, just a little bit wider.
Brian
Scissor Lift (A55851)
Metal Shelving (A47477)
Metal Shelving...
2025 Ratchet Tie Down Straps (A55788)
2025 Ratchet Tie...
ATHEY AB6905 MOTOR GRADER (A52707)
ATHEY AB6905 MOTOR...
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
CUTTING TORCH STAND W/HOSES & VALVES (A55745)
CUTTING TORCH...
