Will Concrete Vibrator Settle Down Slab to Level?
   / Will Concrete Vibrator Settle Down Slab to Level? #11
Over vibrating also destroys the air entrament in the concrete and causes it to have less ability to bend, therefore making it weaker. A vibrator should always be in the hands of an experienced man...
David from jax
   / Will Concrete Vibrator Settle Down Slab to Level? #12
You pound the pins into the ground and fill with concrete after you get it level. In all reality, just getting them a couple inches down is all you really need to do, but if they will go more, that's good too. I use a metal rod that's maybe 3/4 of an inch thick to do this, but just about anything will work.
Good luck,
Eddie
   / Will Concrete Vibrator Settle Down Slab to Level? #13
What we use to do was set 1x2’s stakes with a pair of nails on top to hold a 3/4” pipe of the required length. The pipe worked as a guide for the screed board and then was removed. Throw a little concrete into the void with a shovel and run a bull float over it until flush.
MarkV
2012 Vermeer V500LEHD Vacuum T/A Towable Trailer (A55973)
2012 Vermeer...
2014 Volkswagen Passat TDI SE Sedan (A55853)
2014 Volkswagen...
2014 Ford F-150 4x4 Ext. Cab Pickup Truck (A55852)
2014 Ford F-150...
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
1996 Sunflower 1543-38 Folding Disk (A57024)
1996 Sunflower...
UNUSED FUTURE SF60 60" HYD SIDE SHIFT FORKS (A57193)
UNUSED FUTURE SF60...
