Will my 870 pull a 2 bottom plow?
   / Will my 870 pull a 2 bottom plow? #11
I's say you could pull it, unless the ground was really slick, weigh down front end make sure each bottom is taking an equal bite.
what you might have a problem is fitting a wide rear turf tire in the 12in furrow and especially with coulters you might have ground clearance issues cause turfs are shorter.
   / Will my 870 pull a 2 bottom plow? #12
I have a Kubota B3030 ( I know, wrong forum, but I also have a JD 318, so please cut me some slack /forums/images/graemlins/grin.gif) and I can pull a 2 x 14" plow in sandy ground with no problem. I think my tractor is comparable in size and weight to yours. I do need to be in 4WD and have the loader on for weight. It pulls it better than I thought it would, 7 to 8 inches deep. I don't plan on doing this very much but I had a lawn remodeling job to do and the plow broke up the sod so I could push it around easily with the loader. In the future I'll just use it to plow the garden every year.
   / Will my 870 pull a 2 bottom plow? #13
Using the FEL after some plowing.
Toolguy---That Kubota is a fine looking machine, thanks for posting those pics. It seems to be pulling your plow just fine, I will be in much heavier sod probably and also rockier ground than you are in. I believe I will go with a pair of R1's, should give me a good bit more traction than the turf tires.
   / Will my 870 pull a 2 bottom plow? #15
This is just a thought, but you could try the 2 bottom plow if you already have it. If it doesnt work, take one of the plows off.
You shouldnt have any problem pulling a single 12.
Just my cheap side showing /forums/images/graemlins/grin.gif
I pulled a 14/1 with a 2wd JD 850 with turfs and chains. It would pull it. Problem was I couldnt get it high enough to transport it. I caught myself on roots and had to back around till I was able to go across at a angle.
   / Will my 870 pull a 2 bottom plow? #16
Oleozz,
The R1s will help. Traction will be the limiting factor. Otherwise you should be OK. A 12" plow only needs to go down 6" to do a good job and for food plots that should be plenty. Good luck.
Armstrong 64-405A Torque Wrench (A59076)
Armstrong 64-405A...
2006 Ford F-450 4x4 Service Truck (A56858)
2006 Ford F-450...
2013 Ford Taurus SEL Sedan (A56859)
2013 Ford Taurus...
2010 GMC Sierra 1500 4x4 Crew Cab Pickup Truck (A55973)
2010 GMC Sierra...
Hose Reel (A55758)
Hose Reel (A55758)
2003 UTILITY TRAILER MANUFACTURER UTILITY TRAILER MANUFACTURER (A55745)
2003 UTILITY...
