Will my tractor handle this?
   / Will my tractor handle this? #13
I think youu are set up about right. With 2 rigs mowing at 5-7 mph you can mow than
you can bale in a day. The say you have to mow it befor u can bale, keep
mowing and u should be in good shape.
   / Will my tractor handle this? #14
pulling a 13 to 15 mow/co aint happing with an 85hp tractor.youd need 125hp tractor to pull it.are you the 1 with the 5020JDs.if so they would pull a 15ft mow/co with ease.
   / Will my tractor handle this? #15
I'll say with 85 pto hp, you have just enough hp to run that 10 ft disc mower conditioner. I've got 85 hp on mine and its just enough in heavy yields.
You could run a much wider sickle bar mower condition like a 14 ft centre pull pivot type, but you'd have a sickle type rig. If your ground is smooth, not rocks etc, you could do this easily and save a lot of fuel. My ground isn't like that, I won't go back to sickle bar type if I can help it.
Yeah I have 2 5020s and there just to much tractor I think for a hay field..... I wanta just go with the 9'9" because of gates and traveling up and down the high way.
2009 Yamaha YDRE Electric Cart (A50324)
2009 Yamaha YDRE...
2021 John Deere 333G Two-Speed Hi Flow Compact Track Loader Skid Steer (A50322)
2021 John Deere...
2016 FORD F-350 XL SUPER DUTY CREW CAB FLATBED (A51243)
2016 FORD F-350 XL...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
Unused 2025 CFG MX15RX Mini Excavator (A49461)
Unused 2025 CFG...
Quick Attach Pallet Forks (A47384)
Quick Attach...
