Will new tires help with traction
   / Will new tires help with traction #1
SJay
Tri City Area, MI
Bobcat CT225 Tractor, John Deere 4x2 Gator, Husqvarna Zero Turn, John Deere Buck 650 ATV
As the title states - will I see anView attachment 499334View attachment 499335 improvement in traction with a new set of front tires - the back one are not nearly as worn
Thanks
   / Will new tires help with traction #2
For me it did. I was told its common to replace 3 sets of front wheels for every set of rear wheels.
   / Will new tires help with traction #3
Last summer I changed my AG front tires after almost 300 hr. of use, the rears were still like new, more tread more traction.
   / Will new tires help with traction #4
I am hoping the worn front tires work like turf tires,,, mine are staying,,,
I have 1/4" of tread in the center. The tractor will be used for mowing.
   / Will new tires help with traction #5
Depends what you are working on, deeper tread really only helps in the mud and snow.
Ran a worn out set of 14.9-28's for years, ran chains in the mud and snow. Wet hay field was pulling baler and wagon and not cutting in, would spin out on top. Same tractor with new tires (yay!) Would bite right in and if it spun, chew the field up and dig a hole. Take the new tires, but you might be fine waiting.
Thanks for the replies:thumbsup:
2002-2004 CAT 325C Excavator (A59213)
2002-2004 CAT 325C...
2018 Bomag BW120 SL Tandem Vibratory Smooth Drum Roller (A56857)
2018 Bomag BW120...
JOHN DEERE 6115D TRACTOR (A58375)
JOHN DEERE 6115D...
2019 Kaufman Pro Series Car Hauler Trailer, VIN # 5VGFE4736KL004723 (A57453)
2019 Kaufman Pro...
SD Lanch SDLGC80 Electric Golf Cart (A57149)
SD Lanch SDLGC80...
SKID STEER ATTACHMENT (A58214)
SKID STEER...
