Will Pat's ez change work on cat 2 hitch?
   / Will Pat's ez change work on cat 2 hitch? #1
leeinmemphis
Kubota 5040 with FEL
Will Pat\'s ez change work on cat 2 hitch?
Hey everyone,
I have a Kubota 5040 and was looking at the Pat's Ez change system. It says it will work with cat 1 hitches but doesn't indicate whether it will work on cat 2 hitches or not. Does anyone here know if it will or not?
Hey everyone,
   / Will Pat's ez change work on cat 2 hitch? #3
Re: Will Pat\'s ez change work on cat 2 hitch?
EZ hitch models
1,2, and 3 are avaiable.
John
   / Will Pat's ez change work on cat 2 hitch? #4
EZ hitch models
John
   / Will Pat's ez change work on cat 2 hitch? #5
Pat sells a Cat 2 version as well as Cat 1 and Cat 3
   / Will Pat's ez change work on cat 2 hitch? #6
thanks guys. That isn't the same website that I was looking at. Now I found the info I needed. I'll go on ahead and get it ordered. thanks again!
   / Will Pat's ez change work on cat 2 hitch? #9
</font><font color="blue" class="small">( That isn't the same website that I was looking at. )</font>
You can order through TBN. In your order in the comments section, I'd make sure to mention it's a cat. II that you need as I don't see any other way to make that known.
This will help support TBN.
John TBN Pat's EZ Change
   / Will Pat's ez change work on cat 2 hitch? #10
11' CONTAINER (A51248)
2015 FREIGHTLINER SPRINTER VAN (A52576)
2015 FREIGHTLINER...
2016 New Holland Roll-Belt 450 Round Baler (A52384)
2016 New Holland...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53472)
2019 Krause...
Rock wood travel trailer (A51694)
Rock wood travel...
2025 JMR Stump Bucket Skid Steer Attachment (A51691)
2025 JMR Stump...
