Will Pat's ez change work on cat 2 hitch?
   / Will Pat's ez change work on cat 2 hitch? #1
leeinmemphis
Kubota 5040 with FEL
Will Pat\'s ez change work on cat 2 hitch?
Hey everyone,
I have a Kubota 5040 and was looking at the Pat's Ez change system. It says it will work with cat 1 hitches but doesn't indicate whether it will work on cat 2 hitches or not. Does anyone here know if it will or not?
Hey everyone,
   / Will Pat's ez change work on cat 2 hitch? #3
Re: Will Pat\'s ez change work on cat 2 hitch?
EZ hitch models
1,2, and 3 are avaiable.
John
   / Will Pat's ez change work on cat 2 hitch? #4
EZ hitch models
John
   / Will Pat's ez change work on cat 2 hitch? #5
Pat sells a Cat 2 version as well as Cat 1 and Cat 3
   / Will Pat's ez change work on cat 2 hitch? #6
thanks guys. That isn't the same website that I was looking at. Now I found the info I needed. I'll go on ahead and get it ordered. thanks again!
   / Will Pat's ez change work on cat 2 hitch? #9
</font><font color="blue" class="small">( That isn't the same website that I was looking at. )</font>
You can order through TBN. In your order in the comments section, I'd make sure to mention it's a cat. II that you need as I don't see any other way to make that known.
This will help support TBN.
John TBN Pat's EZ Change
   / Will Pat's ez change work on cat 2 hitch? #10
UNUSED JCT 84" HYD 4N1 BUCKET (A51248)
UNUSED JCT 84" HYD...
UNUSED INDUSTRIAS AMERICA C18 CATTLE LOADING RAMP (A51247)
UNUSED INDUSTRIAS...
2020 Ram 1500 4x4 Crew Cab Pickup Truck (A51692)
2020 Ram 1500 4x4...
BUSH HOG 7007 LOT NUMBER 38 (A53084)
BUSH HOG 7007 LOT...
2015 John Deere 410E 40 Ton Articulated Off-Road T/A Dump Truck (A51691)
2015 John Deere...
2018 Vermeer BC1000XL Towable Brush Chipper (A51691)
2018 Vermeer...
