Will Pats' quick change system work on a BX2230?
   / Will Pats' quick change system work on a BX2230? #11
Re: Will Pats\' quick change system work on a BX2230?
Here's a not so toll-free number
270-422-4544
   / Will Pats' quick change system work on a BX2230? #12
Thanks, I'll give it a try
   / Will Pats' quick change system work on a BX2230? #13
Bluecon,
I don't have Pat's, but I had replied to another BX owner asking this question that I don't think the top link connection will work once Pat's system is on as it will move the bagger back a couple inches. I think if you can come up with a way to extend that piece then Pat's should work fine.
By the way if you do, let me know as this is the main reason I have not decided to pursue a quick hitch or Pat's.
And your right about the bagger being a PIA to attach/detach.
Good luck,
   / Will Pats' quick change system work on a BX2230? #14
</font><font color="blue" class="small">( And your right about the bagger being a PIA to attach/detach. )</font>
Surfran... that is an understatement! I installed mine for the first time last weekend and it took two of us to get the toplink attached. This fall I will design a dolly for the beast and some sort of lift to make it easy to install. After I mow grass this weekend I plan to remove the catcher until fall. Originally, I planned to use the catcher (as needed) when the grass was tall but I will scrap those plans until I come up with a better installation process.
John
   / Will Pats' quick change system work on a BX2230? #15
I've gotten some dimensions back from Pat's, and it looks like some modifications would be needed to install the rear bagger with the Pat's system. The right side lower connection just needs more clearance, so we need to cut the cross-frame to allow the clearance, as well as extending the top connection point to compensate for the 3.5" that the Pat's extends the lower arms. It's staring to sound like work, but it's probably all easily done with some planning.
   / Will Pats' quick change system work on a BX2230? #16
Don't forget about the extra length needed on the PTO shaft.
John
   / Will Pats' quick change system work on a BX2230? #17
@#$% PTO shaft, forgot about that. Now I'm scrounging around for reasons to go with this system. Seems like work.
   / Will Pats' quick change system work on a BX2230? #18
I plan to remove my catcher this weekend. I will see how much extension is available on the shaft. I don't think there is much.
John
   / Will Pats' quick change system work on a BX2230? #19
I use my car jack to provide some lift to the bagger once I have it attached on the lower links. I then rotate the top attach point and put the pin in. It is still a PIA, but at least I don't have to muscle as much. I typically use mine some this time of year, but by mid summer my grass does not require it so I put it up until fall for the leaves.
They really need to come up with a better way to mount though. The units they sell in Europe look intersting, and they dump!!
New Lewis Brothers MFG DB2 Poultry Housekeeper (A53472)
New Lewis Brothers...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2010 Ford Escape Hybrid SUV (A51694)
2010 Ford Escape...
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
(INOP) FORD 2000 TRACTOR (A51247)
(INOP) FORD 2000...
HARDEE RD60M LOT IDENTIFIER 144 (A53084)
HARDEE RD60M LOT...
