Soundguy
Old Timer
- Joined
- Mar 11, 2002
- Messages
- 52,424
- Location
- Central florida
- Tractor
- RK 55HC,ym1700, NH7610S, Ford 8N, 2N, NAA, 660, 850 x2, 541, 950, 941D, 951, 2000, 3000, 4000, 4600, 5000, 740, IH 'C' 'H', CUB, John Deere 'B', allis 'G', case VAC
Spyder... The point that Mike and i are trying to make.. is that 'info' is useless.. if the target audience can't understand it. And by target audience.. I mean at least 80% ( think bell curve here ).
We have people here from engineers to non-tractor-owners.
Look in the repair subs... some people have to ask how to wire up a lamp circuit.
When shooting for that 80% audience..and looking at the entire population you can expect the bottom 10% to still not comprehend your message, and the top 10% to find the message significantly vauge or non technical as to nearly incorrect. In the 80 percentile, you will have more or less a 'top half' that will completely understand the concept being conveyed, and perhaps realize it is not the be-al definition.. but can at least consider it as headed in the right direction.. then you have the bottom half that will understand the info in practicle / usable terms. and even if they do not understand the underlying concepts.. can at least take it at face value for comparison sake.. IE.. observed relationships betweent he advice, and the topic the advice is about.. etc. )
Throw in enough 10$ words.. and you skip right up to that 10% setting outside the curve.
If you want a non tractor analogy here's one.
If I have a bacterial infection, and go to the doctor to get an antibiotic. and while there, I ask the doctor 'why' the antibiotic makes me feel better.. and he tells me that the antibiotic 'kills' the bacteria causing the infection... then.. you know.. that's good enough for most people. I don't really think it's necescary for the doc to go into gram positive and gram negative discussions.. and talk about protien synthesis.. etc.. to tell you HOW/WHY the antibiotic is effecting the disease organism. heck.. in technical terms.. you can find a good many drugs that don't actually kill the organism.. but rather prevent it from doing something... in a technical aspect.. the doc telling you that it's being killed would be wrong.. however.. same observed results for the patient occour.. and he can relate to that.. etc.
Soundguy
Soundguy
