Will the loader from a 2305 fit onto a 2032R?
   / Will the loader from a 2305 fit onto a 2032R? #1
clayhardock
Cochrane Alberta
JD 2720 & 2305 & F932
Considering buying a 2032R. My dad has a 2305 with loader. While talking with the salesman about the 2032 vs 2305 he mentioned that they use the same loader but that the 2032 handles it way better due to its incresed weight and hydraulic flow. Wasn't till I was driving home that I got to wondering, could I use the loader from my dad's 2305 on a 2032? Are they that much the same? or just same specs/performance? My dad and I live next to each other and so I could save a few $$$ and just borrow his when needed.
When you buy a tractor without a loader does it some with the controls and hydraulic points or does that get added with the loader package?
Thx!
   / Will the loader from a 2305 fit onto a 2032R? #2
Tractor will come with loader controls and hydraulic fittings. As for the loader swap,the loaders are the same,but the frame mounts are totally different.
Greg
So if I installed the proper frame mounts onto the new 2032R could I then swap the loader between the 2305 and the 2032r?
   / Will the loader from a 2305 fit onto a 2032R? #4
Yep,I believe so. You and your dad could share the loader.:):thumbsup:
The one thing I would check though,are the hose lengths. Probably the same on all loaders,but I'd make sure. You could pull into the "parked" loader with your 2032,as if you were going to hook up. That should tell you for certain.
Greg
   / Will the loader from a 2305 fit onto a 2032R? #5
Yes you can. I ordered my 2032r with the proper frame mounts and my loader will work on both my 2305 and my 2032r
2009 Ford Crown Victoria Sedan (A56859)
2009 Ford Crown...
2005 TerraGator 8104 (A55302)
2005 TerraGator...
John Deere 1025R (A53317)
John Deere 1025R...
SET OF GOLF CLUBS (A58374)
SET OF GOLF CLUBS...
2007 International 4300 Box Truck, VIN # 1HTMMAAL27H513415 (A57453)
2007 International...
Caterpillar D5G LGP (A53317)
Caterpillar D5G...
