Will welding fry an ammeter on a tractor?
   / Will welding fry an ammeter on a tractor? #21
Even running at 20 amps isn't right.
After a hard start you may see the meter run at 20 but it should start dropping very shortly after that to what ever it takes to operate the tractor. As someone else suggest it could be it's operating correctly now that you've tighten a couple things here and there and the meter just isn't finely calibrated enough to show the small plus charge.
However, charging isn't your problem at moment.
Did you cross wire that new battery on the jumper cables? Or was that the old battery? Sorry I forget.
While you're runn' off for new cables, maybe you should take that new battery into town with you and have it load tested just for giggles.
UNUSED 70PCS Black Metal Roof Panels (A53117)
UNUSED 70PCS Black...
2021 JOHN DEERE 7R230 LOT NUMBER 204 (A53084)
2021 JOHN DEERE...
Golf Cart (A55787)
Golf Cart (A55787)
2018 Toro Workman GTX Electric Utility Cart (A55851)
2018 Toro Workman...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2014 JLG G12-55A 12,000lbs 4x4 Rough Terrain Telehandler (A53421)
2014 JLG G12-55A...
