Winch on a tractor?
   / Winch on a tractor? #11
I used to bury my 8N up to the axles in mud so often that I started carrying a 2 ton come-along and a couple of chains on it. I was always in the woods so it was no problem to find something to hook on to.
The big advantage with the 8N was I could put it into first gear and let it idle with the tires spinning while pulling with the come-along, once it got traction I would get back on it and stop it so I could unhook the chains. Crude, but worked every time.
I used a come-along to pull my Kubota B7100 off a fence corner post that I got lodged against. Hooked it to the drawbar and put enough pressure on it to help the tractor to go a little sideways when I moved (tractor was on a slope and wanted to keep sliding into the post).
I am pleased to announce that I have graduated to a 4 ton come-along these days and haven't had to use it yet but it is in the tractor stall if I need it.
Biggest problem with an electric winch on a tractor is the amperage draw. I have an 8,000 # winch on my Jeep and it will drag a battery down fast if you are pulling real hard. Hydraulic winch would be better on a tractor but hydraulic winches are higher than electric winches (I think but have not checked prices).
Bill Tolle
John Deere 853 20ft Corn Head (A53473)
John Deere 853...
2017 GRAND DESIGN RECREATIONAL MOMENTUM (A53843)
2017 GRAND DESIGN...
200387 (A51247)
200387 (A51247)
SDLANCH MINI WALK BEHIND SDLL30 LOADER (A53843)
SDLANCH MINI WALK...
Hydraulic Power Unit S/A Towable Pump (A53421)
Hydraulic Power...
2008 CHEVROLET C7500 SERVICE TRUCK (A51406)
2008 CHEVROLET...
