Winch to get Unstuck
   / Winch to get Unstuck #1
heitjer
Houston, TX
LS R4041 & LL4100 FEL
All,
I have been unlucky lately and got stuck a few times with my YM2210. I should have gotten the 4x4 but now I am stuck. This tractor will be good ones I reach the end but until then it is foreseeable that I get stuck ones in a while.
So - I do not want to trade it in for something bigger&better. Alternative I am thinking about an old 9N or so as a companion. But my wife has not warmed up to this yet.
Is there an electrical winch that you can recommend that I can mount on the YM2210 to be able to pull me out when I need it?
Thanks!
   / Winch to get Unstuck #2
I would just pony up and get a different tractor (4 X 4)
   / Winch to get Unstuck #3
you can get good 12 volt winches off ebay very cheap.I have a titan 4500 that come with a block on my 2 wheel drive tractor that works great .then you can use it to put attachments on the front
   / Winch to get Unstuck #5
Any of the automotive type winches will work. Just make sure you get enough of a weight rating to pull out your tractor (in my opinion it is 1.5 times the weight of the tractor).
I've thought of this as well. Is there a brush guard out there with a winch mount? It would likely be easily fabricated if not, but is there one already being manufactured?
   / Winch to get Unstuck #6
I recently got my JD 5403 stuck (I hate gophers) and was unwilling to risk getting my truck stuck trying to get it out. It was a Sunday and the only thing nearby that was open was Wallmart. The only wench they had was a off market 1 ton 12 volt model, but it was cheap. While I wish I could have gone to Tractor Supply or somewhere to get a better unit, this little guy with a little help from a shovel and some old tires was enough to get me out. I was about 12 to 16 inches down in the back and more in the front, thanks to the gophers and my tractor weighs about 6000 lbs. So a little help can go a long way.
   / Winch to get Unstuck #7
I've made it a routine to get stuck at least once a week lately (mud), and the 3,000 lb winch on my RTV900 gets me out every time.
I can easily imagine modifying a Harbor Freight winch to the front or back of tractor to get unstuck, but you're going to have to provide the tree... The RTV weight 2,000 lbs, and it makes a good anchor when the operator stands on the brakes.
Good luck!
Thanks Y'all!
I looked around and can get 4500 #'s winch for ~$180 to $220. My tractor weights 2200 #'s so I guess I should be fine. A friend is a welder and he could make me some brackets for the front of the tractor where the Koyker FL sits in.
Any other comments welcome - I will monitor prices and comments for a while.
I have plenty of trees to get pull from.
   / Winch to get Unstuck #9
I had a Ford 1300 2wd with turf tires and I ended up running chains on it year round.
   / Winch to get Unstuck #10
I'm running chains on my R4s, but mud is mud, and I sink/chainsaw to the chassis. I really have no business trying to do field work this early in the season.
   / Winch to get Unstuck #11
In the rare event that I get stuck I just use the loader and bucket to assist getting unstuck. I guess a winch has other handy functions too now that you have it.
   / Winch to get Unstuck #12
I am sure glad I got 4WD! I have been working the woods this week. No trouble at all. Man is it muddy. In fact I have only been stuck once and I still don't understand why I got stuck in that place under those conditions.
Depending on the winch you may need to upgrade to a battery that will handle the load better.
Chris
2014 Freightliner 105' Bucket Truck (A61306)
2014 Freightliner...
TPL MECHANICS BODY LUBE SKID (A60429)
TPL MECHANICS BODY...
FARMHAND 827 FEED MILL (A60430)
FARMHAND 827 FEED...
2016 INTERNATIONAL PROSTAR TANDEM AXLE DAY CAB (A59904)
2016 INTERNATIONAL...
PALLETS OF HEAVYEQUIPMENT (A58214)
PALLETS OF...
SWICT 72" SKID STEER BUCKET (A60430)
SWICT 72" SKID...
